WTB, Fan Shaft grease cup
Topic author - Posts: 3814
These parts are not listed separately in the parts book. I want to stipulate the entire assembly is solid brass and screws onto the fan shaft. Don't want a reproduction. Need the grease cup and the nut it screws onto.
- First Name: Avery
- Last Name: Jones
- * REQUIRED* Type and Year of Model Ts owned: 1923 Ford Model T Runabout
Re: WTB, Fan Shaft grease cup
Just clarify that you need the whole assembly in solid brass, including the grease cup and the nut, and that you're looking for original parts, not reproductions. That should help narrow down your search.
Can't say I've ever seen a brass nut one Larry - I've got original steel ones.
- First Name: Karl
- Last Name: VonNeumann
- * REQUIRED* Type and Year of Model Ts owned: 1916 touring 1927 tudor 1926 hotrod 1913 speedster (project) 1926 coupe (project)
- Board Member Since: 2022
Never seen a brass one either only steel grease cups
Understand that your looking for originals not repros.Original Smith wrote: ↑Mon Aug 05, 2024 12:15 pmThese parts are not listed separately in the parts book. I want to stipulate the entire assembly is solid brass and screws onto the fan shaft. Don't want a reproduction. Need the grease cup and the nut it screws onto.
Just to confirm: when you say you want the entire assembly ... then... Need the grease cup & the nut it screws into. Did you mean the assembly (cup with nut) that screws onto the fan shaft end.
