Want to buy left side rear #3 buffalo hub
FlyingMerkel
Topic author - Posts: 87
- First Name: Daniel
- Last Name: Kraft
I’m looking to buy a left side rear buffalo #3 hub. I also want to buy a complete set of #3 caps, as well as two wheel centers, or wheels. I have most of a set, and would like to complete it.
FlyingMerkel
- Last Name: Kraft
Kevin Pharis
- First Name: Kevin
- Last Name: Pharis
Layden Butler
- First Name: Layden
- Last Name: Butler
Re: Want to buy left side rear #3 buffalo hub
Would be curious to know what over size axle the rear hub was made to fit?
Too big for a T and I think too small for a TT.
Kevin Pharis
- First Name: Kevin
- Last Name: Pharis
I’m thinking yur lookin at a giant weld to hold in a replacement taper…
FlyingMerkel
- Last Name: Kraft
A T axle is 1.062" where the taper starts. Try it on a bare axle. I see 1.187".
FlyingMerkel
- Last Name: Kraft
I’ll put a micrometer on it.
Daniel, rear Hayes wire wheel hubs, more often than not, have flogged out keyways. I fix these by machining down a good T hub and boring out the Hayes hub to take the machined T hub. You might be able to do the same to make that hub fit.
