Want to buy left side rear #3 buffalo hub
FlyingMerkel
First Name: Daniel
Last Name: Kraft
Post by FlyingMerkel » Fri Mar 20, 2026 9:56 pm
I’m looking to buy a left side rear buffalo #3 hub. I also want to buy a complete set of #3 caps, as well as two wheel centers, or wheels. I have most of a set, and would like to complete it.
FlyingMerkel
First Name: Daniel
Last Name: Kraft
Re: Want to buy left side rear #3 buffalo hub
Post by FlyingMerkel » Fri Mar 20, 2026 9:58 pm
Here’s a picture of what I have.
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Sat Mar 21, 2026 12:45 pm
Email sent
Layden Butler
First Name: Layden
Last Name: Butler
Post by Layden Butler » Sat Mar 21, 2026 2:15 pm
Would be curious to know what over size axle the rear hub was made to fit?
Too big for a T and I think too small for a TT.
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Sat Mar 21, 2026 3:23 pm
I’m thinking yur lookin at a giant weld to hold in a replacement taper…
FlyingMerkel
First Name: Daniel
Last Name: Kraft
Post by FlyingMerkel » Sun Mar 22, 2026 7:48 pm
This isn’t model T size?
First Name: john
Last Name: karvaly
Post by speedytinc » Sun Mar 22, 2026 8:05 pm
A T axle is 1.062" where the taper starts. Try it on a bare axle. I see 1.187".
FlyingMerkel
First Name: Daniel
Last Name: Kraft
Post by FlyingMerkel » Sun Mar 22, 2026 8:15 pm
I’ll put a micrometer on it.
Post by Allan » Mon Mar 23, 2026 7:44 am
Daniel, rear Hayes wire wheel hubs, more often than not, have flogged out keyways. I fix these by machining down a good T hub and boring out the Hayes hub to take the machined T hub. You might be able to do the same to make that hub fit.
