Rods
Topic author - Posts: 263
- First Name: DEAN
- Last Name: YODER
- * REQUIRED* Type and Year of Model Ts owned: 19tour,24tour,25rdpu,27rd.26coupe,TT's,& tractor conversions
Rods
Picking out a set of rods to bore for My 25 roadster pu
Re: Rods
Dean,that round thing on the bench in front of the stove tells me you are on the right track!
- First Name: DEAN
- Last Name: YODER
Re: Rods
Allan, When I babbitt rods I start with cores that weigh +- 10 grams with the babbitt wiped out. After poring the sprue is removed and bore to 1.2 inch then weigh again. This makes it easier to get a balanced set.
Re: Rods
Way to go Dean. I don't do my own babbit work, but I do select a set of rods of es near as possible the same weight to send off for work. Makes sense to get things as close as possible to give a good start.
- Last Name: Warren
Re: Rods
Looks like a relaxing hobby
