Model T Gas Headlights Piping
ModelTMark
Topic author - Posts: 83
- Last Name: Williams
- * REQUIRED* Type and Year of Model Ts owned: 1924 TT, 1923 Touring, 1927 Tudor, 1915 Roadster
I have an early 15 Roadster with gas lights, but it's missing all the piping between the lights and the carbide generator. Can anyone tell me how the gas line is routed from the generator to the head lights? All I have is new red rubber tubing and the short gas pipe section mounted across the bottom of the radiator, like on the 14 Ts? Where is the Tee fitting located? Where there clamps attached to the frame that held up the copper pipe? Was there any provision for a drain in gas line? Does anyone have any pictures that can be posted?
Thanks, Mark
Thanks, Mark
Re: Model T Gas Headlights Piping
I've never heard of a factory equipped gas headlight system. If there was such a thing, it certainly did not use copper fittings.
While maybe true from the factory with gas lights, but I have wondered about the early ones made in late 14 if they got the new style body and if they had gas or electric lights, same with the tourings that still had the 1914 carry over bodies built in early 15.
The fittings would have been brass. I think the copper ones sold by the suppliers are for show only, not for real use. Copper and acetylene make a nasty gas. You might try googling mtfca 1914 gas headlights
viewtopic.php?t=2012
The 3 holes for the clamps are unique. How late were they provided?
This may help too.
http://www.mtfca.com/discus/messages/25 ... 1345771412
This may help too.
R.V.Anderson
- First Name: R.V.
- Last Name: Anderson
Copper (or its alloys such as brass) and acetylene do form explosive acetylides, but in a properly functioning gas headlamp system they are carried off and burned in the lamps as soon as they form.
ModelTMark
Early 15 open cars did come from the factory with gas headlights. I hate to say it, but who ever says they didn't is wrong.
- Last Name: Strange
Earlier discussions on the subject:
https://www.mtfca.com/encyclo/1915-16H.htm
http://www.mtfca.com/discus/messages/82 ... 1527859810
http://www.mtfca.com/discus/messages/59 ... 1465890913
http://www.mtfca.com/discus/messages/257047/284488.html
http://www.mtfca.com/discus/messages/29/24151.html
http://www.mtfca.com/discus/messages/17 ... 1309404068
http://www.mtfca.com/discus/messages/59 ... 1455763853
