About to be on the road again - 1910 Ford racer
Rob
Topic author - Posts: 1562
- First Name: Rob
- Last Name: Heyen
Our 300 cu in motor is almost finished. Tony Schafers, lead instructor at our local college took on the motor after some damage last summer. This is how it looks now. Awaiting the headgasket, then back together and into the car. We’ve had tremendous support with this project, from Fawcett Restoration in Canada, Dean Yoder, Mike Vaughn and Bruce Van Slone with electrical and transmission, and Ben at No Coast Custom and Rod. Stan Howe rebuilt the big five ball carb, and we’re about to put it on the road again.
Re: About to be on the road again - 1910 Ford racer
Looking GOOD again!
- Last Name: Hjortnaes
What a beautiful shop he has got there.
Kaiser
- First Name: Leo
- Last Name: van Stirum
Such a big beautifull beast that motor...
were those extra oil lines an original fixture or did you add them for safety ?
Thanks for sharing the pictures !
Leo van Stirum, Netherlands
MWalker
- First Name: Mike
- Last Name: Walker
What happened to it last summer that caused it to be worked on again?
KeithG
- First Name: Keith
- Last Name: Gumbinger
That engine looks beautiful and I'll bet that it'll run even better. Can't wait to see and hear it run!
Keith
Keith
Rob
- First Name: Rob
- Last Name: Heyen
Thanks guys. Yes, Dave, amazing shop.
I think I overheated the motor last summer, and there was scoring on the pistons and cylinder walls. Fortunately we were able to hone the cylinders, but needed new pistons. When Tony got into the motor, the crankshaft also didn’t turn well (videos below) and was binding. The shaft was straight and the bearings were fitted, but evidently not in line. He did a little sanding and brought everything into line.
Before:
https://www.dropbox.com/s/aaydr5fc7f9ye ... M.mov?dl=0
After:
https://www.dropbox.com/s/72b7r9chw7nje ... M.mov?dl=0
Screenshot of before video:
Before:
After:
Sean B
- First Name: Sean
- Last Name: Bittle
A thing of beauty!!
Now Rob. Was that a test to see if we noticed in the first video that you tightened the nuts on the bearings too tight and forgot the shims, and then you left off the bearings and nuts in the second video so it would spin so well? Everything looks so nice and clean. Does Tony scrub that shop down every night?
jburns79se
- Last Name: Burns
- * REQUIRED* Type and Year of Model Ts owned: 1912 speedster
LOVE those bucket seats! jburns79se@aol.com
RustyFords
- First Name: Don
- Last Name: Allen
"Cool" seems inadequate, as do "Neat" and "Impressive".
1924 Touring
Rob
- First Name: Rob
- Last Name: Heyen
Stopped in today to check on a few things. Pics include the 09 style waterpump, magneto drive with dual spark Bosch mag and deflector shield over auxiliary exhaust ports:
Gil Fitzhugh
- First Name: Gilbert
- Last Name: Fitzhugh
That's going to make your K roadster seem downright wimpy and boring. You may need to unload it on someone who appreciates wimpy and boring. Me, for instance.
Susanne
- First Name: Susanne
- Last Name: Rohner
I want to know where you found the dual spark Bosch... all the dual spark goodies are getting hard to find any more, even the formerly somewhat common Delco Dual Distributor setups aren't easy to put ones hands on.
Bud Delong
- First Name: Kenneth
- Last Name: DeLong
Rob,Was that very heavy flywheel balanced while the other work was done? Bud.
Rob
- First Name: Rob
- Last Name: Heyen
Gil, nice try..........
Susanne, the dual spark was with the motor/project. It’s similar to the one on the 410 cubic inch Ford Special racer at THF. I don’t know if it was with the motor originally, or found and added to the project at some point in time.
Bud, the motor was balanced by Fawcett restoration last year. We only honed and replaced pistons and rings, so hopefully everything is still in balance. We shall soon see...........
