Measurements on Auxiliary Transmission Support U Bolts
ModelTWoods
Topic author - Posts: 1511
- First Name: Terry
- Last Name: Woods
Does anyone have an auxiliary transmission support like the one pictured? It is suspended from the frame by two U bolts. I have the bar but need the dimensions to make U bolts to fit. The slotted holes in the support are big enough for 3/8 to 7/16 bolts. The measurements of the slotted holes in the support bar vary from a minimum of 1 1/2" between slots, to a maximum of 3 3/4".
Re: Measurements on Auxiliary Transmission Support U Bolts
Terry
Don't have any measure, but this photo is from eBay on one listed now.
Maybe you can extrapolate the length of the U bolts from this photo.
Shane Lach
- First Name: Shane
- Last Name: Lach
- * REQUIRED* Type and Year of Model Ts owned: 1927 Tudor and 1921 speedster in progress
Hey Terry I have some warford u bolts and a cross member if that would help you? Not the same cross member but if you need the whole thing I'd let it go. I also sent you a pm about a manifold setup you had mentioned a while back.
ModelTWoods
- First Name: Terry
- Last Name: Woods
Dan, the support that you pictured is at model T haven. I have messaged mark through EBAY to get the measurements from him for the U bolt, but after two requests, he still has not responded, so I posted here.
ModelTWoods
- First Name: Terry
- Last Name: Woods
Shane, I think I'll stick to the type of support that I have. I can make U bolts for it. I will send private message about Model A/Model B manifold setup.
