Dome pistons with Low Head?
Last Name: Hatch
Post by Dan Hatch » Mon Jun 08, 2020 12:01 pm
Guys: Question, will dome pistons clear a low (early) head?
Thanks Dan
First Name: Henry
Last Name: Lee
Re: Dome pistons with Low Head?
Post by Henry K. Lee » Mon Jun 08, 2020 12:07 pm
You will have to do some impression work with real soft clay Dan. Some will and some will not. I have had to in the past, machine down the pistons to get them right.
Just Sayin’
Hank
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Mon Jun 08, 2020 1:42 pm
I run that combination in my 13. I did check carefully for clearance with NO head gasket!!
I was lucky in that the block and head didn’t need much surfacing
Last Name: Hatch
Post by Dan Hatch » Mon Jun 08, 2020 1:49 pm
Thanks guys.
modeltbarn
First Name: Gary
Last Name: London
Post by modeltbarn » Mon Jun 08, 2020 2:36 pm
I've done this in 4 engines. Only one needed a little flap disking in one cylinder for the head to lie flat on the block without a gasket. I haven't tried a 09-10 head, but my '11 is runnung an early 11 head with this. The other heads have been in the '14 and up variety.
Susanne
First Name: Susanne
Last Name: Rohner
Post by Susanne » Mon Jun 08, 2020 5:13 pm
Mine does... I'm running an earlier head (early '12) than motor (late '15) as the original head keeps developing cracks... but both cleared the pistons no problem!
