Berg's Radiator
Topic author - Posts: 1559
- First Name: Don
- Last Name: Allen
Berg's Radiator
I have to brag on Berg's Radiators for a minute.
I installed the new flat-tube Berg's radiator in my T last year, just as the hot weather was ending in Texas. The highest temp it saw before things cooled down was just under 90 degrees. Hot, mind you, but nowhere near what the Houston area can dole out.
Over the weekend, my thermometer noted temps just shy of 100 degress. I ran the 24 Touring to the convenience store a few miles away and sat at a stop light for what seemed like an eternity then took the long way home (about 15 miles). The radiator handled it like a champ.
1924 Touring
Re: Berg's Radiator
That is what a good radiator should do! However, appearance wise, they look nothing like the originals.
- First Name: Don
- Last Name: Allen
Re: Berg's Radiator
That's the beauty and fun of stepping away from perfect restorations, like I've done with this car. I'm not attached to anyone's rule book.Original Smith wrote: ↑Tue Jun 09, 2020 1:53 pmThat is what a good radiator should do! However, appearance wise, they look nothing like the originals.
1924 Touring
- First Name: Danny
- Last Name: Deaton
Re: Berg's Radiator
Good looking T
I like it
I like it
- First Name: Bill
- Last Name: Harper
- * REQUIRED* Type and Year of Model Ts owned: '14 Touring, '20 TT Farm Truck, '24 TT Depot Hack, '24 Coupe, and a 1914 Metz Model 22 Torpedo Runabout
Re: Berg's Radiator
Don Allen (RustyFords) wrote:
"my thermometer noted temps just shy of 100 degress"
My goodness, isn't that WAY lower than Normal Operating Temperature (NOT) for a Model T?
I had always understood that NOT was around 190 degrees. Running any engine colder that at its designed operating temperature results in inefficient combustion, loss of power and poor fuel consumption.
Or am I wrong? 'Splain me, Lucy.
I put a flat tube Brassworks radiator on my '24 coupe and that poor little thing just would not warm up. After I installed a 190 degree thermostat it became a happy camper. I wondered if I would have been better off buying a round tube radiator.
Your mileage may vary, Bill
Bill Harper
Keene, New Hampshire
- First Name: Duane
- Last Name: Cooley
Re: Berg's Radiator
Man, you guys are tough. You can handle 100 degree ambient temperatures!
It's 76 outside and that's blinking warm.
- First Name: Don
- Last Name: Allen
Re: Berg's Radiator
1924 Touring
- First Name: Don
- Last Name: Allen
Re: Berg's Radiator
100 degrees is roughly the Normal Operating Temp for planet Earth near Houston, Texas in the summertime.
Dunno what the temp of the Model T coolant was. I didn’t measure it, Ricky.
1924 Touring
- First Name: Susanne
- Last Name: Rohner
Re: Berg's Radiator
The only think I see wrong with that radiator... is that it's not belching steam and coolant. Then again, all I have by comparison is my ancient and clogged radiator...
- First Name: Don
- Last Name: Allen
Re: Berg's Radiator
Yeah...I tried the belching steam and coolant version.
Quaint, but not practical.
1924 Touring
- First Name: Philip
- Last Name: Thompson
Re: Berg's Radiator
same thing here i put one in my car and all cooling issues vanished i dont even carry water anymore. philip
