If you need help logging in, or have question about how something works, use the Support forum located here
Support Forum
Mel King
- First Name: Melvin
- Last Name: King
Post
by Mel King » Tue Feb 12, 2019 6:43 pm
I installed the crank I had ground in 1980 and come to find out it is .003 out in center main and the inner thrust is .007 on one side and drags on the other but the flange is square.
It is fresh .020 all. Any help ?,I live in Portsmouth ,VA. I have 2 other cranks I think are junk but I hate to throw them away. One is .005 on front main and .030 on rear . The other is .015 front and .025 rear. Any ideas? I"m at a stand still!!
MEL.
Post
by Mark Gregush » Tue Feb 12, 2019 6:52 pm
Have the crank check for straightness, built up the rear thrust and refit for correct end play.
Kevin Pharis
- First Name: Kevin
- Last Name: Pharis
Post
by Kevin Pharis » Tue Feb 12, 2019 7:57 pm
Having been ground near 40 years ago I see a couple possibilities. 1) a crank not stored properly can sag under its own weight over time. 2) Or it was ground wrong in the first place. It is widely known that crank grinders hold the crank between centers (using axial pressure) and this will spring the crank, after grinding it will resume its original shape and appear bent
Mel King
- Last Name: King
Post
by Mel King » Wed Feb 20, 2019 6:47 pm
Who is able to straighten a T crank close to Portsmouth ,VA? MEL.
