Reconnecting wishbone problem.
22centerdoor
Topic author - Posts: 30
- First Name: David
- Last Name: Stauffacher
- * REQUIRED* Type and Year of Model Ts owned: 1922 Centerdoor
I just adjusted my rod beatings. I removed the inspection cover on a 4-dip pan which necessitated disconnecting the wishbone ball socket. When putting it all back together, the ball socket does not line up with the pan. It is about 3/8 of an inch off. Is this normal? Is there some type of trick to get the wishbone and pan to align? Thanks.
MWalker
- First Name: Mike
- Last Name: Walker
Re: Reconnecting wishbone problem.
Lift it up using a floor jack and it should slip into place.
John iaccino
- Last Name: Iaccino
- * REQUIRED* Type and Year of Model Ts owned: 1911 Roadster, Open Runnabout
Try connecting the front and rear axles together with a ratchet strap. Tighten the strap and it should slip right in.
