Cork Gaskets
SurveyKing
First Name: Daniel
Last Name: Snell
* REQUIRED* Type and Year of Model Ts owned: 1909 Touring, 1924 Touring, 1925 Roadster Pickup, 1921 Touring
Board Member Since: 2014
Cork Gaskets
Post by SurveyKing » Sat Jun 20, 2020 10:01 am
Does anyone know if Cork Gaskets are being reproduced and if so where?
Rich Bingham
First Name: Rich
Last Name: Bingham
Re: Cork Gaskets
Post by Rich Bingham » Sat Jun 20, 2020 10:49 am
I have heard forest fires in Portugal some fourteen years ago or so practically ended the cork industry which may never recover. You may have noticed how plastic stoppers have replaced corks in your favorite vino ?
Any road, the “pure” sheet cork (made from ground up cork) used for gaskets always was rather problematic, being fragile and prone to dry out and shrink. If it’s still made, later “cork” gasket sheeting where the cork granules were embedded in a rubber-like matrix was (is?) much superior. If you can find it, you could cut your own gaskets, but that’s not what you asked. Gaskets I’ve ordered recently are a paper-type material, but very adequate. Most of us depend on slathering on gobs of RTV gasket sealer anyhow ! :lol:
"Get a horse !"
Squirrel
First Name: Jim
Last Name: Forbes
Re: Cork Gaskets
Post by Squirrel » Sat Jun 20, 2020 11:31 am
Sorry, I don't know. But I would like some too.... I recently took apart the engine in my 27, and it had cork gaskets for the pan, and even a cork front seal. It had not been leaking, except at the Bendix cover, which gasket was not cork, and had been slathered with RTV by PO.
Although the lack of leaks from the cork up front, might also be partly attributable to the plugged oil funnel and tube :)
Re: Cork Gaskets
Post by DanTreace » Sat Jun 20, 2020 11:48 am
There are no Model T motor kits with cork anymore.
But sheet cork gasket material (aviation grade) is made. I keep a roll in the drawer for making gaskets for things that don't have 'em. :)
SurveyKing
First Name: Daniel
Last Name: Snell
Re: Cork Gaskets
Post by SurveyKing » Sat Jun 20, 2020 12:15 pm
It seems that if the cork rolls are made, the gaskets could be cut with a template of some sort. Too bad nobody is doing that. I have heard that Henry used the cork which absorbed oil and kept the seal. I am thinking that if I got the roll and cut my own gaskets plus put on the silicone gasket sealer, that should do the trick pretty well.
Duey_C
First Name: Duane
Last Name: Cooley
Re: Cork Gaskets
Post by Duey_C » Sat Jun 20, 2020 12:43 pm
I too prefer cork in some places and have made my own forever. Especially tin covers of any kind but I seldom use sealant.
Head down to your favorite parts store also for cork rolls.
jab35
Last Name: Bartsch
Re: Cork Gaskets
Post by jab35 » Sat Jun 20, 2020 1:04 pm
Last Name: Hatch
Re: Cork Gaskets
Post by Dan Hatch » Sat Jun 20, 2020 1:35 pm
Ask and you shall see.
https://www.ebay.com/p/227053136
Dan
Re: Cork Gaskets
Post by RajoRacer » Sat Jun 20, 2020 2:45 pm
Olson's Gaskets in Port Orchard, WA can make any gasket you need from different materials !
Rich Bingham
First Name: Rich
Last Name: Bingham
Re: Cork Gaskets
Post by Rich Bingham » Sat Jun 20, 2020 3:37 pm
Hasn’t everyone made their own gaskets one time or another using a ball-pein hammer ? :shock:
(Works best with “paper” gasket stuff)
"Get a horse !"
Re: Cork Gaskets
Post by RajoRacer » Sat Jun 20, 2020 3:56 pm
Sure have - but Olson's has a computer plotter !
Rich Bingham
First Name: Rich
Last Name: Bingham
Re: Cork Gaskets
Post by Rich Bingham » Sat Jun 20, 2020 4:09 pm
I’m guessing they have Model T gaskets on file, then ?
Thanks for that source Steve !
(Bearing them out with a hammer really isn’t a LOT of fun ! :lol: )
"Get a horse !"
Last Name: Seth
Re: Cork Gaskets
Post by perry kete » Sat Jun 20, 2020 4:09 pm
Are cork rolls good with coffee?
Duey_C
First Name: Duane
Last Name: Cooley
Re: Cork Gaskets
Post by Duey_C » Sat Jun 20, 2020 4:37 pm
If ya drizzle caramel on top!
Re: Cork Gaskets
Post by Scott_Conger » Sat Jun 20, 2020 6:23 pm
The paper gaskets available today are far superior to what I recall being marketed 5-6 years ago. I detest picking cork shards off of, and out of the engine or transmission when having to perform work that requires removing covers, so greatly appreciate paper and a little schmeer.
No matter HOW careful you are, you will invariably find cork bits in the transmission screen after reassembly and running. That tells me all I need to know.
You didn't ask, but I'll say: Paper for me.
Re: Cork Gaskets
Post by Allan » Sat Jun 20, 2020 10:20 pm
Rich's first response re cork disappearing from wine bottles due to shortages is correct in part. Any shortages would only have only had the effect of hastening the change-over to plastic seals, because the plastic seals are a far more consistent seal. Even high end wines now come that way, as spoilage from traditional corks failing is/was a major problem in marketing wines of a consistent quality.
Which makes it very difficult to find one piece corks to make new floats for Standex fuel tank gauges for model T's.
Re: Cork Gaskets
Post by RajoRacer » Sat Jun 20, 2020 10:23 pm
Allan - I replace my old cork floats for those type of gauges with the new composite Model A gas gauge floats - works really good.
D Stroud
First Name: David
Last Name: Stroud
Board Member Since: 2011
Re: Cork Gaskets
Post by D Stroud » Sun Jun 21, 2020 12:41 am
I'm with Scott Conger. I never did like cork gaskets, still don't. I can't recall one time that when I went to use one, it wasn't shrunk, and that goes all of the way back to the 50's. :x JMHO Dave
1925 mostly original coupe.
dmdeaton
First Name: Danny
Last Name: Deaton
Re: Cork Gaskets
Post by dmdeaton » Sun Jun 21, 2020 11:40 am
I like cork 😁
Ruxstel24
Last Name: Hanlon
Re: Cork Gaskets
Post by Ruxstel24 » Sun Jun 21, 2020 11:51 am
Are you wanting a specific gasket in cork, or a set Dan ? I think Mr Morsher cleaned me out.
Dropacent
Last Name: Morsher
Yup !Cork Gaskets
Post by Dropacent » Sun Jun 21, 2020 12:31 pm
Yup! Dave’s got a memory like a steel trap
Duey_C
First Name: Duane
Last Name: Cooley
Re: Cork Gaskets
Post by Duey_C » Sun Jun 21, 2020 1:56 pm
Lotsa nice goodies!
david_dewey
First Name: David
Last Name: Dewey
Re: Cork Gaskets
Post by david_dewey » Sun Jun 21, 2020 3:57 pm
making gaskets with a ball pien hammer was one of the things my Dad taught me when I was still in grade school. I remember surprising the college engine rebuilding class's instructor with known how to do it, when a gasket was missing. Maybe I'm strange, but I find it an enjoyable task. Of course, I don't have to do it all the time either!
T'ake care,
David Dewey
SurveyKing
First Name: Daniel
Last Name: Snell
Re: Cork Gaskets
Post by SurveyKing » Sun Jun 21, 2020 4:12 pm
Looking for gaskets for the Transmission Cover and Inspection Plate, also the Starter and Bendix Cover.
Susanne
First Name: Susanne
Last Name: Rohner
Re: Cork Gaskets
Post by Susanne » Sun Jun 21, 2020 5:51 pm
I remember learning that, too, back when I was younger - I'm not terribly good at it but it works in a pinch, even with gasket paper. I do better marking the sheets with a super fineline marker or pencil and cutting them out. Just did a pair of valve spring cover gaskets that way...
I shoud measure the thicknesses of the various gaskets and stock up on sheet cork. Not sure if the Buna-N impregnated would be better or not...
Duey_C
First Name: Duane
Last Name: Cooley
Re: Cork Gaskets
Post by Duey_C » Sun Jun 21, 2020 8:18 pm
Mr Dewey, I find it therapeutic and useful too, no matter the material. Duey. :)
Susanne, me neither. Not very good at it with some castings. If they're sharp edged? Presto. Nice gasket. ;)
Too darned busy, cheap, lazy and short on materials to make punches (gosh they're cheap to buy too) sometimes so I use a 1/2 check ball to pop the holes out.
On earlier notes: I agree. Cork will dry and shrink. Is there a way to rejuvenate old cork or paper gaskets that have dried and shrunk?
Water? Oil?
Dropacent
Last Name: Morsher
Re: Cork Gaskets
Post by Dropacent » Sun Jun 21, 2020 9:09 pm
Water will swell a paper gasket that has shrunk. Done it many times, and one supplier even used to put a note with their gasket sets. I’ve never tried it on cork, but would probably depend on composition. If anyone really wants cork, as you can see I have a supply. Glad to help out, just ask.
First Name: Dallas
Last Name: Landers
Re: Cork Gaskets
Post by Dallas Landers » Sun Jun 21, 2020 9:56 pm
Duey, different caliber rifle or handgun cartridges work great for punching holes in gaskets. Just make sure their spent! :D
Duey_C
First Name: Duane
Last Name: Cooley
Re: Cork Gaskets
Post by Duey_C » Mon Jun 22, 2020 12:42 am
:lol:
:lol:
