14 mm spark plugs
Jfmarkham
Topic author - Posts: 33
- Last Name: Markham
- * REQUIRED* Type and Year of Model Ts owned: 1923 pie wagon
14 mm spark plugs
A while back I bought the 14 mm plug adapters but Lange don't tell you what plug you should use anyone using a 14 mm plug if so what make and number
ModelTWoods
- First Name: Terry
- Last Name: Woods
Re: 14 mm spark plugs
I'm not sure whether the plug heat range makes a big difference depending on whether you are running an iron or aluminum head, but it might. Snyder's recommends using Champion RC12YC in their aluminum Model A head. From a previous discussion of this subject on the MTFCA forum, question posed by Mark Chaffin, the consensus of several post respondents was Bosch 4203. Three other mentioned were: Bosch 4501, Autolite 216, and Autolite 66.
Lang’s list 14mm spark plugs along with the 14mm plug adapters. They are Autolite plugs. They list them on their web site and catalogue.
