Gas Line 24 Coupe
frenesse
First Name: Ron
Last Name: frenette
Gas Line 24 Coupe
Post by frenesse » Wed Jul 01, 2020 8:19 pm
Took my gasline out while ago and cant remember if the new one goes over or under the hump cross frame? Does it even matter?
Ron
Re: Gas Line 24 Coupe
Post by John kuehn » Thu Jul 02, 2020 10:03 am
Here’s the routing information. Hope it helps. I also have a 24 Coupe and this is the way I did it.
frenesse
First Name: Ron
Last Name: frenette
Post by frenesse » Thu Jul 02, 2020 3:03 pm
John
I saw this but tought it did not show what I needed. But when you sent it I looked at it closer and realized it does show what I need. If you had not sent I would still be out in the ozone still looking around. Thanks
Ron
Post by John kuehn » Thu Jul 02, 2020 6:17 pm
Yes the gas line goes over the hump. When I bought the gas line a few years ago it came with the reprint from Ford about installing the gas line.
I found out that my car didn’t have the gas line clamp and it was missing. So I had to order the clamp. Iv’e had the car over 50 years and it had been taken off before I inherited it in 1959.
If you look closely at the print you can see the clamp.
