Hi there, I installed new stainless valves and adjustable lifters in my 1926 T. I just put the valve and lifters in and adjusted the valves to .014. Engine starts fine but engine lacks power. Should I have taken head off and re-time valves?
Thank you
Valves
Topic author - Posts: 16
- First Name: Phil
- Last Name: Terry
- * REQUIRED* Type and Year of Model Ts owned: 1926 tudor
- First Name: Joe
- Last Name: Bell
Re: Valves
Did you lap in the valve seats? I recut the seats then lap them in for a good seal. Hope this helps.
Re: Valves
"If you need help logging in, or have question about how something works, use the Support forum located here"
You need to ask your question on the main forum, this is not car support.
