Adjustable Two Piece Valve lifter Question
George Hand
Topic author - Posts: 310
- Last Name: Hand
- * REQUIRED* Type and Year of Model Ts owned: 1912 open express, 1920 touring, 1926 tudor-lisenced and insured, 1921tt project 1922 fendered chassis, 192x tt dootle bug 192xengine w/winch projects
Hope to be getting ready to assemble an engine soon & I was wondering if & what are you taking off the valve stems prior to installing new valves. For this build I will be using new vendor provided stainless valves. Thanks George
Tim Williams
- Last Name: Williams
- * REQUIRED* Type and Year of Model Ts owned: 1925 Model T Speedster, 1922 Model t Speedster project
Re: Adjustable Two Piece Valve lifter Question
are your lifters adjustable? When I did mine which had non adjustable lifters of all the new valves, I only had to grind one stem to get the clearance. with adjustable lifters i wouldn't think you would have to grind any of the stems. if my thinking is not correct please I welcome the input.
Tim
Tim
paddy1998
- Last Name: Delaney
- * REQUIRED* Type and Year of Model Ts owned: 1922/23 Touring
I just did mine with the new stainless valves.George Hand wrote: ↑Wed Jul 08, 2020 11:10 amHope to be getting ready to assemble an engine soon & I was wondering if & what are you taking off the valve stems prior to installing new valves. For this build I will be using new vendor provided stainless valves. Thanks George
I took off about .100 or so to get room to adjust. I just did it with the grinder in stages measuring as I went. As I recall they were 5.076 and I knocked them down to anywhere from 5.010 to 4.985 give or take. The Harbor Freight digital caliper came in handy.
Careful, those stems get HOT!
If I had to do it again I would buy for the special installation tool and the special thin adjustment wrenches.
paddy1998
Note: You should test the fit before deciding if you need to grind the stems. Out of the box my clearance was around .006 or less, which is why I ground the stems down.paddy1998 wrote: ↑Wed Jul 08, 2020 12:10 pmI just did mine with the new stainless valves.George Hand wrote: ↑Wed Jul 08, 2020 11:10 amHope to be getting ready to assemble an engine soon & I was wondering if & what are you taking off the valve stems prior to installing new valves. For this build I will be using new vendor provided stainless valves. Thanks George
Careful, those stems get HOT!![]()
