Will any overhead valve head fit in 27 coupe without firewall modification?
Richard
Overhead valve
Dan McEachern
- First Name: DAN
- Last Name: MCEACHERN
Re: Overhead valve
There is a version of a B Rajo where the back of the head is sloped to clear a 26/27 firewall.
Kerry
- Last Name: van Ekeren
Re: Overhead valve
Rajo's fit but the rocker cover is modified for the 26/7 fire wall. But the problem I found was they stink of oil fumes being open at the back of the rocker cover, removed my 4 valve for that reason.
old_charley
- First Name: Bryan
- Last Name: Ostergren
- * REQUIRED* Type and Year of Model Ts owned: 1914 cut-off touring/pickup: 1922 Touring car: 1921 TT Dump Truck
Re: Overhead valve
Rajo also made the Model C35 to fit the '26 cowl without cutting into it. I have one, and the rear of the cover doesn't fit well enough to seal worth a darn.
TonyB
- First Name: Tony
- Last Name: Bowker
Re: Overhead valve
I thought the four valve Rajo Model A was designed specifically to fit a standard firewall. The Four valve A will give you a much power as you need, they are plenty fast from my experience. JMHO
Tony Bowker
La Mesa, California
La Mesa, California
