Making Holley G floats
Post by Allan » Sat Jul 18, 2020 3:26 am
I have a slug of the black stuff the vendors sell for the purpose, but I am looking for guidance on how to work with it. I have a lathe. I have some expanding mandrels to take emery cloth cylinders like a drum sander. I have a band saw, and a Dremel kit. What else might I need and how should it be used?
Rich Bingham
First Name: Rich
Last Name: Bingham
Re: Making Holley G floats
Post by Rich Bingham » Sat Jul 18, 2020 10:14 am
Stuff I have is a sort of “foam”, very easy to form, and a wee bit fragile, actually. It’s easy to shape by hand with a fine saw and sandpaper. Perhaps there’s more than one species of synthetic float material ?
"Get a horse !"
Last Name: House
Post by George House » Sat Jul 18, 2020 11:30 am
Allan; I think Stan Howe is making 2 floats for me out of that same material for two U & J carbies I sent him. Contact him. Hes very helpful albeit long winded 😁
George Hand
Last Name: Hand
Post by George Hand » Sat Jul 18, 2020 12:24 pm
Snyder's list a float for the Holly G, I bought one several years ago for my bronze/brass G, their listing list for 1918-20 (steel body) but it worked fine in my carb. The only thing is the nuts on the screws can loosen up so I would add a drop of solder to each once you hinge is
to the new float assembled. price $14.95 T-6102G
AndreFordT
First Name: Andre
Last Name: Valkenaers
Post by AndreFordT » Sat Jul 18, 2020 1:01 pm
I think it is this one you are talking about.
I not only use it in the holley G carburetor. I take it as base to build other floats as I can't find the right one. It is an easy material that gives good results but while grinding and sculpting it to fit you need to wear a mask.
Last time I used it was for the rebuild of the float for a four balls kingston
Andre
Belgium
Vrayfoster
First Name: Victor
Last Name: Foster
* REQUIRED* Type and Year of Model Ts owned: 1910 Touring, 1915 Touring
Board Member Since: 2002
Post by Vrayfoster » Sat Jul 18, 2020 3:26 pm
i have been using the black ring as per the previous post for years and not had a bit of trouble with my Holley G. I was unaware of the screws loosening and haven't had that problem yet. However, that makes me think to buy new brass screws from the bolt depot and replace the original screws.
