The discs are original style and all looked fine with minor discoloration, except for two which had about a dime sized build up of carbon.
I removed the carbon using a plastic scraper and some sandpaper, thoroughly washed all the discs with soap and water, rinsed and dried thoroughly and then reinstalled with a liberal application of some ATF between each disc (what I saw Mike Bender do in the Model T Tips video on Youtube) and reinstalled the pressure plate and spring. At no time did I touch or adjust the clutch fingers at all.
After getting the engine back in the car I took it out for a short test drive and noticed one big difference. Before I pulled the engine I would shift into high gear by running up to speed in low, then in swift motion moving the pedal to neutral, reduce throttle some, and then quickly release the pedal. This method always resulted in what felt like a smooth engagement of high gear; no jerking or anything like that.
During my test drive when I quickly released the pedal to engage high gear in the manner described above, the shift was very hard, jolting in fact. Almost gave myself whiplash!
Anyway, is that normal?
Should I ease the pedal back when engaging high gear instead of "popping" it as I has been doing before?
