T932 steering bracket, what does it go to?
schwabd1
First Name: David
Last Name: Schwab
Post by schwabd1 » Thu Jul 23, 2020 11:14 pm
What does this T932 steering bracket go to?
Squirrel
First Name: Jim
Last Name: Forbes
Re: T932 steering bracket, what does it go to?
Post by Squirrel » Thu Jul 23, 2020 11:57 pm
it's in the 1910 price list
3539 Steering post bracket with bushing ... 2.50 Tubregano 932
Last Name: House
Post by George House » Fri Jul 24, 2020 6:38 am
That looks like a ‘26-‘27 steering column bracket in really bad shape. It fastens to the left frame rail with 3 bolts and the brass bushing slips over the bottom end of the steering column also encompassing the spark and gas rods.
schwabd1
First Name: David
Last Name: Schwab
Post by schwabd1 » Fri Jul 24, 2020 8:35 am
I found a picture of the 1926 T932 on the "Ford Fix" site..... I've never messed with a '26 - '27, I didn't know they had such a short bracket. I'm not planning on using it for anything. The one flange is pitted pretty bad, it has been floating around in my box with steering brackets and just wondered what it was used on. Thanks for your input.
Post by Jerry VanOoteghem » Fri Jul 24, 2020 9:34 am
Yes, it's shorter, and it also brings the steering column shaft closer to the frame than earlier brackets do. This accommodates for the wider bodies used in 26/27. They're not for use on pre-26 cars.
Last Name: House
Post by George House » Fri Jul 24, 2020 12:49 pm
In actuality there’s 2 styles of this bracket in the last 2 years of T production. The rarest only fits the 4 door and chassis. The other style fits all the other body styles of 26-27. Just a tidbit I’ve learned from this Forum
