scat crank shaft and rods
				Rich Huggins
- First Name: Rich
- Last Name: Huggins
- * REQUIRED* Type and Year of Model Ts owned: 1923 touring- 1922 deverley truck -1922 center door
Having trouble finding  main bearings scat crank 4.25 stroke bearing's are Fm gm 2965 ra ul std. Has scat main caps clam shell bearings, found rod bearings no problem clevite cb 278 p std any help!
				Rich Huggins
- First Name: Rich
Re: scat crank shaft and rods
Have found bearings will have them soon! The new scat crank was reground and model a bearing caps bored to except clam shell bearings bearings that are from a mg. A lot of time spent looking for the bearings and stepped beyond my budget this engine was built 2011 has less than 100 miles on it and down due to clearance problems crank hit oil line and pistons kissed the head, scat crank only have babbitt bearings is what i was told by scat
