Found something interesting?
Last Name: Hatch
Post by Dan Hatch » Thu Jul 30, 2020 11:33 am
I was parting out some heavy rods, you know saving rod bolts and pin bolts. When I noticed this on a set.
A full set of DB made rods. I have seen a lot of DB parts, first set of rods. Dates them to pre 13? What DB parts have you got? Thanks Dan
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Re: Found something interesting?
Post by Dan McEachern » Thu Jul 30, 2020 12:49 pm
Great find!
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Thu Jul 30, 2020 5:42 pm
That is a find Dan!
Kerry
Last Name: van Ekeren
Post by Kerry » Thu Jul 30, 2020 5:55 pm
Canadian engines still had DB heavy rods until 1916.
Last Name: Hatch
Post by Dan Hatch » Thu Jul 30, 2020 6:47 pm
I am sure they were used till they were all gone. Just like Ford did with everything. But did not ford stopped using DB for parts around 13?
Gene_French
First Name: Gene
Last Name: French
Board Member Since: 2014
Post by Gene_French » Thu Jul 30, 2020 7:46 pm
Dan:
i have a bunch of Dodge Brothers parts ... a complete 1925 touring car , a 1917 Roadster cut down and several chassis ... great cars , powerful and reliable ... always an optimist Gene French
John Warren
Last Name: Warren
Post by John Warren » Sun Aug 02, 2020 4:15 am
I have an engine in my 25rpu that was rebuilt when I got it. Before I ran it I took the oil inspection pan off to install dippers, if they weren't already. Three heavy rods and one regular rod with some flat washers making up the difference in weight. I... installed the dippers and put it back together. It is the smoothest engine I have been around. What are you going to do with the heavy rods, I would be interested. Thanks.
Last Name: Hatch
Post by Dan Hatch » Sun Aug 02, 2020 8:28 am
John: Email me at address in pictures. I have some heavy rods.
Post by John kuehn » Sun Aug 02, 2020 9:53 am
Interesting post about the old style rods.
Without a doubt lots of the old style heavier rods were sent to the scrap yard over time.
Most vendors won’t take them for a core for rebabiting so the question would be what to do with them.
I have a few still around somewhere if I haven’t thrown them out.
Maybe some one would put together an engine with older style engine and transmission parts for originality someday.
Now that would be interesting!
Colin Mavins
First Name: Colin
Last Name: Mavins
Post by Colin Mavins » Sun Aug 02, 2020 10:11 am
The rods that came out of the 12 when I broke the crank were DB rods we put the light weight rods in I also have the cast pistons and pins that were changed 60 years ago Dad kept every part .
Post by Original Smith » Sun Aug 02, 2020 10:34 am
My '13 had the DB rods when I got it. That was in 1961.
Greg Griffin
First Name: Greg
Last Name: Griffin
* REQUIRED* Type and Year of Model Ts owned: '14 torpedo, '25ish pickup
Post by Greg Griffin » Tue Aug 04, 2020 7:35 pm
I put heavy rods and cast iron pistons back in my '14. Straight-cut timing gears, too. Oh, and my valve stems are not adjustable. Round tube radiator. My '14 is a '14! It's my idea of fun.
