Kingston 5 Ball for 1909
StanHowe
First Name: Stan
Last Name: Howe
Post by StanHowe » Fri Aug 14, 2020 12:45 pm
I posted a couple pics of the new caps for this a week or two ago, thought I post a pic or two of it done and off to the owner. It had been whacked with a wrench, a hammer and whatever else, lotsa bruises that hadn't healed on their own, took a little massage to get it looking good.
There is always some controversy over the air inlet tube and design. This is how it came in except the hat was squished flat. This is how it goes out. Right or wrong, correct or not, it went away.
Quickm007
First Name: Mario
Last Name: Brossard
Re: Kingston 5 Ball for 1909
Post by Quickm007 » Fri Aug 14, 2020 12:54 pm
Splendid! Nice Work Stan!
Super Mario Bross ;)
1911 Touring
1914 Speedster
otrcman
First Name: Dick
Last Name: Fischer
Post by otrcman » Fri Aug 14, 2020 12:58 pm
Like most men, fancy diamonds and jewelry don't excite me much. But a perfectly cleaned up and operational brass carburetor ? Now, that really turns my crank !
Bravo, Stan !
R.V.Anderson
First Name: R.V.
Last Name: Anderson
* REQUIRED* Type and Year of Model Ts owned: 1914, 1920, 1923, 1923
Post by R.V.Anderson » Fri Aug 14, 2020 2:02 pm
Well if that works half as good as it looks....
Post by Rich Eagle » Fri Aug 14, 2020 2:16 pm
It is always a treat to see things we will never have or clean up that nicely.
I feel I owe something to just look at it but......
I'm perpetually in awe of you accomplishments.
Last Name: House
Post by George House » Fri Aug 14, 2020 2:53 pm
....should be in the Smithsonian with all the other national treasures. Gorgeous work Stan !!
VowellArt
First Name: Martynn
Last Name: Vowell
Board Member Since: 2012
Post by VowellArt » Fri Aug 14, 2020 8:41 pm
Stan...does it have some other designation other than 1909, Kingston 5 ball? Anything different about it other than the air intake?
Fun never quits!
StanHowe
First Name: Stan
Last Name: Howe
Post by StanHowe » Sat Aug 15, 2020 1:31 am
Not that I know of. The air intake varies from year to year but the body of the carb is the same as near as I can tell. The later ones also added a butterfly choke but that is also part of the air intake.
Bob McDaniel
First Name: Bob
Last Name: McDaniel
Post by Bob McDaniel » Sun Aug 16, 2020 1:23 am
So how does the 5 ball compare to later Kingston's as far as performance?
Joe Bell
First Name: Joe
Last Name: Bell
Post by Joe Bell » Sun Aug 16, 2020 6:57 am
The mushroom seems to be always missing, they must of vibrated off in the day.
Pat Branigan Wisc
Last Name: Branigan
* REQUIRED* Type and Year of Model Ts owned: 1909 two1910,1911, 1913 Tourings
Post by Pat Branigan Wisc » Sun Aug 16, 2020 8:44 am
I have ran a Five Ball for over twenty years on my 1910 and 1911 and have worked well for me. Rebuilt them with a Brass float and new needle and seat.
StanHowe
First Name: Stan
Last Name: Howe
Post by StanHowe » Sun Aug 16, 2020 10:05 am
I was using a brass float but have some new synthetic material I like better which can be shaped like the original cork float.
I make a needle of my own design that uses the original seat. I do not like drilling out the original seat to put a modern type seat in.
Most of those do not pull the needle open as this design does.
But there are lots of ways to do it, mine is just one way.
