Post
by jab35 » Wed Aug 19, 2020 11:04 pm
Steve, reply to your earlier post:
Post by jab35 » Thu Aug 13, 2020 12:38 pm
Steve: I've done one single stack, probably won't do another, the vendors do it better and faster.
I would never roast or cook a core to clean it, too much risk of warping the frame. The original shellac was a bigger challenge than the oil, I washed off most of the oil with kerosene, let it dry and then soaked in denatured alcohol softening the shellac until I could remove the coils without damaging them, since I re-used the copper. (I think all rewound single stack are done these days with new copper strip, I think double stack still re-use the copper) Various solvents, scotch pads and even course steel wool worked for me to clean up the strips. I made sure there were no dings in the strip that might work thru the insulation. Before I rewound the copper I stretched each strip about 4" (~4" in 12' = ~3% strain) which made it straight and flat.
I used McM-Carr p/n 7574A11 fiberglass tape for the between layers and overwrap insulation. That tape silicone insulation is rated up to 500F and is 0.007" thick, comparable to original paper insulation thickness. I split the 1/2" wide tape for application to the strip and used full 1/2" for overwrap. The original Ford overwrap was cotton twill according to one source I talked to.
For the insulating washers between the coil and frame I used 0.020" thick fishpaper, available in sheets from McM, thinner might work better for between coil insulators on double stack.
For final topcoat insulation, clear Glyptal 1202 electrical varnish. I first 'glued' the fishpaper discs and individual coils to the ring with the 1202, waited a day, made and verified the electrical connections and then saturated the entire assembly with liberal brush coat of the varnish. (Apply liberally, don't just give a hairspray coating from a spray can like some videos show). Let it cure a day or two and then bake at 200F for an hour to finish cure. The 200F and one hour bake is from the Glyptal manufacturer, and there is very little smell from the oven.
Andre shows how it all goes together and his work is excellent. RV has excellent products, and very fair prices.
Have fun, jb
