radiator hose
bobt
Last Name: Thompson
radiator hose
Post by bobt » Mon Aug 24, 2020 8:19 pm
Does anybody know where I can buy radiator hose for my 1926 model t roadster without ordering it from a model t parts supplier? Part numbers? Tractor supply? Agra supply? NAPA? I'm not a big fan of those red hoses Lang's and the like sell. It does not have to be original. I drive my t"s ALOT. Thanks, bobt
david_dewey
First Name: David
Last Name: Dewey
Re: radiator hose
Post by david_dewey » Mon Aug 24, 2020 8:25 pm
Local Auto Parts store--at least that's where I bought some the last time (been a few years)
Sold by the inch, I believe!
T'ake care,
David Dewey
Re: radiator hose
Post by TRDxB2 » Mon Aug 24, 2020 9:52 pm
Would set of Model A hose work? Just a thought - can the T hose b painted with Engine Paint (good to 500 degrees F)
Adam
First Name: Adam
Last Name: Doleshal
Re: radiator hose
Post by Adam » Mon Aug 24, 2020 10:14 pm
The set of three hoses from the T parts dealers are generally less expensive than anything else you can buy locally. The red can be changed to black with leather shoe dye.
Mustang1964s
Last Name: Bourgeois
* REQUIRED* Type and Year of Model Ts owned: 1914, 1926, 1927
Re: radiator hose
Post by Mustang1964s » Mon Aug 24, 2020 11:03 pm
I went to Autozone and found the same size hose. It was on an elbow and I ended up having cutting the hose to fit.
It is still on the car. My car is a kid friendly driver. It will not be a 100 point show car.
Erik Johnson
First Name: Erik
Last Name: Johnson
Re: radiator hose
Post by Erik Johnson » Mon Aug 24, 2020 11:36 pm
Correct me if I'm wrong. A while back didn't the vendors also carry a Gates brand three piece radiator hose set in black?
I remember a friend of mine installing them on his 1912 touring (however, that was 25 years ago).
bobt
Last Name: Thompson
Re: radiator hose
Post by bobt » Tue Aug 25, 2020 5:45 am
It's not the COLOR red that I don't like, It's the quality of the hose. Thanks, bobt
Mark Nunn
Last Name: Nunn
Re: radiator hose
Post by Mark Nunn » Tue Aug 25, 2020 8:11 am
I installed a new set of red hoses last spring. I have no complaints whatsoever about their quality.
Re: radiator hose
Post by DanTreace » Tue Aug 25, 2020 9:36 am
Robert
Doubt that any auto parts store will have 'sized' hose for the Model T, it is an obsolete auto ;)
What you can find at most, or order on-line are lengths of hose the correct diameter, then cut the hose to your needs.
Upper hose is 2"i.d. x 4" length. Lower hose is two, each 1 3/4"i.d. x 2 3/4" length.
Most lengths are typical 3' or so. Have used before authentic hand wrapped black and red hose, with thick 7/16" wall, good quality. Duplicate of early hose from Restoration Supply Co. Bought length and trimmed for application. Most modern hoses will have some markings printed on them.
Typical on-line offerings
Re: radiator hose
Post by Mark Gregush » Tue Aug 25, 2020 10:01 am
When I got my radiator hose at the auto parts store for the 1920 Dodge I had to buy by the foot. The Dodge hoses are smaller in diameter so I didn't ask about T size hose nor have I compared the construction/thickness of the 2 types of hose. I have had no issues with the red hose sold by the suppliers. If you are having problems with it sealing, could it be the condition of the water inlet and outlet that are on your car? If it is the clamps, it has been recommended to use the worm type to set it then replace them with the original type if that is what you are going to use.
If you buy local, you may or may not, have to trim to fit.
Re: radiator hose
Post by TRDxB2 » Tue Aug 25, 2020 11:43 am
John Codman
Last Name: Codman
Re: radiator hose
Post by John Codman » Tue Aug 25, 2020 11:58 am
I installed a set of red hoses from Lang's on August 26, 2014 (yup - six years ago tomorrow); I have had absolutely no issues with them, and if Lang's is still getting them from the same supplier I would unhesitatingly recommend them.
bobt
Last Name: Thompson
Re: radiator hose
Post by bobt » Tue Aug 25, 2020 3:47 pm
NAPA had the hose I needed made by Gates. I just had to cut it to length. Thanks guys, bobt
Re: radiator hose
Post by TRDxB2 » Tue Aug 25, 2020 4:58 pm
Can you please add the NAPA part number to this discussion in case others want to follow your choice?
bobt
Last Name: Thompson
Re: radiator hose
Post by bobt » Tue Aug 25, 2020 6:22 pm
Sure. I threw my receipt away but the number on the hose is - Gates 24232 green stripe. This only fits the top " ID hose, sold by the foot. bobt
bobt
Last Name: Thompson
Re: radiator hose
Post by bobt » Tue Aug 25, 2020 6:24 pm
TWO INCH ID TOP HOSE. Sorry. bobt
Quickm007
First Name: Mario
Last Name: Brossard
Re: radiator hose
Post by Quickm007 » Thu Aug 27, 2020 11:06 am
I installed a set of red hoses from Lang's on my both cars; I have had absolutely no issues with them neither. So let's buy there, the price is really fair too. Only $9,50 for the set
Regards,
Hose 2.JPG (26.61 KiB) Viewed 4104 times
Super Mario Bross ;)
1911 Touring
1914 Speedster
Re: radiator hose
Post by Steve Jelf » Thu Aug 27, 2020 12:06 pm
I believe the red hoses in my touring have been in there for twelve years, and so far no leaks. I've had them off several times, and my installation procedures have evolved. I use original style clamps, but I replace the round head screws with fillister heads so the screwdriver can get a good grip. If the inlet or outlet is pitted, I apply a layer of Ultra Black to fill the pits and form a gasket. I smear grease on the inside of the hose so the Ultra Black won't glue it in place. This works for me. YMMV.
I have also figured out that when I remove a radiator to pull the engine it's less hassle to unbolt the inlet and outlet from the engine and leave them in the hoses.
RustyFords
First Name: Don
Last Name: Allen
Re: radiator hose
Post by RustyFords » Thu Aug 27, 2020 1:16 pm
I tried to make the red hoses with OEM syle clamps work, but had tiny leaks no matter what I did.
What ended up working for me was the red hose with OEM style clamps on the lower hoses with a smear of Ultra Black. On the upper hose, I used a modern Gates hose with relatively modern clamps (with a slotted head....from the 1960's) and a smear of Ultra Black.
That installation was about a year ago and none of it has leaked a drop.
If my car was a correct restoration, the modern hose would bug me. But it's not....and it doesn't.
The fact that the Ultra Black will make the hoses hard to remove was taken into consideration. But my thinking is that they shouldn't need to be removed for a long time. My radiator is a new Berg's unit and I change the coolant once a year to keep it as clean/fresh as possible. If and when I need to remove the hoses, I'll just cut them off if necessary and get a new set.
1924 Touring
Mark Nunn
Last Name: Nunn
Re: radiator hose
Post by Mark Nunn » Fri Aug 28, 2020 9:02 am
This is topic-drift. The ribs that seal to hoses on my inlet and outlet were also pitted. I filled the rib pits with JB weld and smoothed them before assembly. There are no leaks and I expect that hoses will come off easily when needed.
