For All Eternity
Redleg
Last Name: Neal
* REQUIRED* Type and Year of Model Ts owned: 1925 Roadster Pickup
For All Eternity
Post by Redleg » Wed Aug 26, 2020 10:52 am
I swear that at the end of my life, should my Maker decide to send me to that warmer place, I will spend all eternity seeking the Ford engineer who aligned the Bendix cover screws with the transmission pedal linkage for surely he occupies the darkest corner of that place.
John Neal
Virginia
‘25 Roadster Pickup
Re: For All Eternity
Post by Rich Eagle » Wed Aug 26, 2020 11:02 am
Punch him a couple of times for me too.
Part of your distress comes from trying to do it on a Roadster. A '17 to '22 Coupe is much easier through the suicide door. At least you can get both hands close to the problem.
Best Wishes,
DLodge
First Name: Dick
Last Name: Lodge
Post by DLodge » Wed Aug 26, 2020 11:26 am
My understanding is that automotive engineers who are sent to the "other place" are condemned to spend eternity working on the cars that they designed in life.....
Post by Mark Gregush » Wed Aug 26, 2020 11:30 am
I have had the same thoughts when installing the parking brake springs and brake clevis pins on Model A rear end! What were they thinking? :o
Post by Steve Jelf » Wed Aug 26, 2020 11:35 am
Last Name: Hatch
Post by Dan Hatch » Wed Aug 26, 2020 11:39 am
Look for the guy that put the oil cooler on the 460 in motor homes. That looks like someone’s after thought. Short hose , bigger round that long with no space to install it.
Maybe same guy did bypass hose on 390 too.
RustyFords
First Name: Don
Last Name: Allen
Post by RustyFords » Wed Aug 26, 2020 11:47 am
He'll also be with the Honda guy who made it necessary to remove the right front suspension, front bumper and radiator on an Odyssey minivan in order to change an alternator.
It'll be a large room/lava pit/cauldron...there'll be a guy from Jaguar in there with several others I can think of.
1924 Touring
HPetrino
First Name: Henry
Last Name: Petrino
Post by HPetrino » Wed Aug 26, 2020 12:00 pm
I had an Acura TL, 2004 if I remember correctly. A headlight bulb burned out. Per the manufacturers published instructions the only way to change that #@%&@ bulb was to first remove the entire front bumper cover, then dig your way in from there.
Post by Norman Kling » Wed Aug 26, 2020 2:17 pm
That is easy if you start the bolt nearest the transmission first and then slide on the bendix cover. The other screws are harder than that one. Another such problem is the nut on the crankcase ear which goes through the wood block and frame on the same side as the starter. I have found the easiest way for me is to use a box end wrench with masking tape around the socket and then press the nut in place. Then crawl under the car turn the bolt from the outside while manuvering the nut around until the thread starts to engage. Then the cotter pin must be inserted with a long nose pliers. I only bend the end of the cotter just enough to keep it from sliding out if the nut spins with the pin down. This too is harder on a car without the drivers door.
FordFool
First Name: Don
Last Name: Kirtley
* REQUIRED* Type and Year of Model Ts owned: 13 and 16 touring, 18 and 20 coup, 20 tudor
Board Member Since: 2009
Post by FordFool » Wed Aug 26, 2020 2:39 pm
I put Allen heads in mine. Use a ball end wrench. No problem. Don
John Warren
Last Name: Warren
Post by John Warren » Wed Aug 26, 2020 3:00 pm
My father always said that if the engineers had to change it before they could have their supper, like he had to, it would have been designed differently. A split screw driver ( Kline K23 ) makes those screws much easier, as long as the screws have a decent slot. Usually you will find these screwdrivers in the electrical tools.
split screw driver.jpg (13.97 KiB) Viewed 5643 times
Bill Robinson
First Name: Bill
Last Name: Robinson
* REQUIRED* Type and Year of Model Ts owned: '21 Depot Hack, '25 Touring Car, '26 Roadster Pickup, '27 Tudor, & another '27 Tudor
Post by Bill Robinson » Wed Aug 26, 2020 4:32 pm
Allen Screw Driver- thanks to Reid Welch's post
Back around the turn of the century there was an active forum member named Reid Welch from somewhere in Florida. A thread was started regarding the pain of installing and removing the slotted bendix screws. Pictured below is Reid's answer. The picture is my donated screwdriver that I cut off and welded a short 1" piece of an allen wrench to the screwdeiver shaft. Once the driver is inserted into the allen screw it stays put and allows you to wiggle the screw through the shafts and align it with the threaded hole, horizontally. Overall length is very important. I have used the screwdriver many times over the years on my T's and helping many friends. It's still working now....and For All Eternity.
Post by DanTreace » Wed Aug 26, 2020 5:41 pm
The good thing about design engineers mistakes, it make a nice business for making solutions and making money on inventions!
Period adv. for those pesky Bendix screws.
IMG_3720 (450x600).jpg (134.28 KiB) Viewed 5558 times
Choice tools in the T tool box, small screw holding screwdriver with release sleeve. Plus an old time one. The extra long single slot is used to finish the tightening, or for removal, as it reaches easy past the brake pedals and cams.
Last Name: Hatch
Post by Dan Hatch » Wed Aug 26, 2020 6:47 pm
Split screwdriver??
That is what we all called “Monday Morning Screwdriver “
If I have to explain, you won’t understand. Dan
StanHowe
First Name: Stan
Last Name: Howe
Post by StanHowe » Wed Aug 26, 2020 7:00 pm
They are 14-24 thread screws. Next time you are ordering something from McMaster Caar or MSC, order box of 14-24 FILLISTER head screws. Makes it a lot easier to keep them on the tip of the screw. Take a nice long screwdriver, grind the tip until it will just start in the slot, tap it in the slot with a lbbfh so it holds the screw on the tip and go to work. Makes a miserable job maybe not easy but not that bad. Cost you about 5 bucks for a box of 25. Makes it a lot easier to get them out, too.
Post by Allan » Wed Aug 26, 2020 7:52 pm
John, it's not the engineer's fault. Blame it on Henry for his contrary decision to make his T models Left Hand Drive. We have no problems where the wheel is on the right side
Bill Dizer
First Name: Bill
Last Name: Dizer
Board Member Since: 2014
Post by Bill Dizer » Wed Aug 26, 2020 8:21 pm
Post WW2, it's will it go down the assembly line, and will it make it out of warranty! After that you are on your own! Try an oil pan on a late 90's s-10 blazer, bravada, jimmy 4x4! Front axles, right side axle extension, front differential, oil cooler lines, flywheel cover, starter etal! Or Pontiac grand am water pump on the 4 cylinder engine on the rear below the exhaust manifold, run by the timing chain! Or another favorite, 86 up Ford Taurus heater core! Drain a/c, pull entire steering column down, loosen entire dash, remove heater box. 9 hrs or so book time, much much less after you have done some, and know the tricks!
StanHowe
First Name: Stan
Last Name: Howe
Post by StanHowe » Wed Aug 26, 2020 11:50 pm
The two things that made me sell my 62 T bird convertible were 1. The windshield wiper motor is accessed through the radio speaker hole. It is recommended to REMOVE THE WINDSHIELD for better access. If I was ever going to do it again I would have to lose 50 lbs, take agility training for 6 months and then have knee pads that allowed me to access the wiper motor with one hand while turned away -- facing the rear of the car -- and taking the 5 nuts off that have to be removed to pull the motor up out of the speaker hole. I would remove the windshield and the hood or sell the car if I ever had to do it again.
2. Heater core. Instruction one: Remove the dash assembly from the car. It took me two days to get it out, replace the heater core and put the dash back in it. In about 1995 or so I was quoted $600 by a shop that worked on them. I would pay it in a heartbeat. A heartbeat!!!!! There is a panel that can't be removed -- since it is a unit body -- that runs from side to side and everything is accessed through the holes in that panel.
I did this about a month after I replaced the wiper motor.
Somebody in California bought it when I sold it at Barrett Jackson, I cashed the check and drove a 47 Chevy Fleetline sedan home from Arizona. I've only owned one other car I was happier to see gone than that T Bird. (A Subaru Outback) The top mechanism????? I was the world expert after three years with that thing.
Alan Long
First Name: Alan
Last Name: Long
Post by Alan Long » Thu Aug 27, 2020 12:02 am
I agree with Allan from Gawler, never had an issue with Pedals or Linkage while working on the Starter! Our issues
are starter Buttons melting, and the steering column getting in the way of Timers, Generators and Fuel lines.
Even back in my days working at Borg Warner we had vast differences with our product from state to state.
Hilly NSW used to have Torque Converter failures and WA broken differential tubes.National meetings about issues
were very interesting. Alan in Western Australia
Vic_alberta_Canada
First Name: Vic
Last Name: Patterson
* REQUIRED* Type and Year of Model Ts owned: 1920 Canadian Touring 1926 Canadian TT Grain truck
Post by Vic_alberta_Canada » Thu Aug 27, 2020 1:13 am
Fancy screwdrivers! as a retired electrician we always just whittled a stick to hold and start the screw!
Post by Allan » Thu Aug 27, 2020 6:11 am
My trick may work with the screwdriver you already have. Fit a short length of rubber fuel line over the end of the screwdriver. Plug the screw into the end of the fuel line to hold it in place and screw away as you like. Easy-peasy!
cessna53195
Last Name: Skingley
* REQUIRED* Type and Year of Model Ts owned: 1913 Runabout
Post by cessna53195 » Thu Aug 27, 2020 12:18 pm
The fact that these screws are #14-24 usually means they are the original ones and quite often the slot is pretty worn out. A tinkering tip I have used before is the toilet bowl wax ring I have on the work bench. Just put a wad of wax on the end of the screw and it will hold right on...Wax ring is great to lube the springs, threads, oil lamp locking slides, head light rims, wheel rims just use your imagination. Another positive is it is friendly with paint...every work bench needs one...Robert
