Installing hardened seats
KenHaverhill
First Name: Kenneth
Last Name: LeBlanc
* REQUIRED* Type and Year of Model Ts owned: 27 coupe 23 touring 26 TT Snowmobile 22 TT Dump Truck 26 Fordoor
Post by KenHaverhill » Mon Aug 31, 2020 7:52 pm
Can someone tell me what i need for a cutter and pilot and where i can get them? I need to install a seat on a 26 block, i have heard you can use a magnetic drill press . I plan to use one of the ones the dealers sell. Thanks
First Name: Henry
Last Name: Lee
Re: Installing hardened seats
Post by Henry K. Lee » Mon Aug 31, 2020 8:43 pm
A lot of seat cutters are adjustable and the guides are in the kit with .0005 increments. My Sioux system is old as dirt but I love it. Might want to check your size requirements and check the Bay.
Hank
Last Name: Hatch
Post by Dan Hatch » Mon Aug 31, 2020 8:48 pm
KO Lee (Hank any kin?) made a portable one you could use in car.
I assume that the engine is still in car if you are only doing one seat. Dan
DickC
First Name: Dick
Last Name: Cruickshank
Post by DickC » Tue Sep 01, 2020 8:08 am
Sorry I can't help with the name of the seat cutter but I borrowed one to do it on my engine. It took about 5 minutes after the set up that took 15 minutes. After the set up I used a 3/8 driver drill to run the cutter. I couldn't believe it. I have been told that these set ups are worth gold if you can find them.
First Name: Adrian
Last Name: Whiteman
Post by A Whiteman » Wed Sep 02, 2020 5:03 am
Phew! Reading the thread title I wondered "Why would you put wooden boards to replace the sprung padded ones..."
Close call that...
