Installing hardened seats
KenHaverhill
Topic author - Posts: 99
- First Name: Kenneth
- Last Name: LeBlanc
- * REQUIRED* Type and Year of Model Ts owned: 27 coupe 23 touring 26 TT Snowmobile 22 TT Dump Truck 26 Fordoor
Can someone tell me what i need for a cutter and pilot and where i can get them? I need to install a seat on a 26 block, i have heard you can use a magnetic drill press . I plan to use one of the ones the dealers sell. Thanks
- First Name: Henry
- Last Name: Lee
Re: Installing hardened seats
A lot of seat cutters are adjustable and the guides are in the kit with .0005 increments. My Sioux system is old as dirt but I love it. Might want to check your size requirements and check the Bay.
Hank
Hank
- Last Name: Hatch
KO Lee (Hank any kin?) made a portable one you could use in car.
I assume that the engine is still in car if you are only doing one seat. Dan
DickC
- First Name: Dick
- Last Name: Cruickshank
Sorry I can't help with the name of the seat cutter but I borrowed one to do it on my engine. It took about 5 minutes after the set up that took 15 minutes. After the set up I used a 3/8 driver drill to run the cutter. I couldn't believe it. I have been told that these set ups are worth gold if you can find them.
- First Name: Adrian
- Last Name: Whiteman
Phew! Reading the thread title I wondered "Why would you put wooden boards to replace the sprung padded ones..."
Close call that...
Close call that...
