Removing the Steering Wheel
BLB27
Topic author - Posts: 892
- First Name: Bruce
- Last Name: Brakke
Can the steering wheel be removed on a 1927 T with out a puller?
Re: Removing the Steering Wheel
Yes, no, maybe all depends on how tight it is.
The wheel is keyed on a parallel shaft, so there is no taper to break. If you sit in the car and load the wheel with pressure from your legs while tapping on the shaft with a soft faced hammer, it should come off. Or, you can remove the wheel/shaft/steering box cover as a unit, the same hammer can be used to drive the shaft out of the wheel.
Hope this helps.
Hope this helps.
BLB27
- First Name: Bruce
- Last Name: Brakke
Allan, I did what you said and off it came! Thanks.
