HCCT Trouble shooting
Andy Loso
First Name: Andy
Last Name: Loso
Post by Andy Loso » Mon Sep 28, 2020 9:27 pm
I have a SSECO HCCT that I am having troubles getting the spark to jump the ring. It has a rebuilt Weston meter on it and will fire the coil and make the meter work, but it will not spark on the spark ring. By hooking up a test light to ground and then touching the spark ring it will 'spark' the test light. This is a SSECO HCCT, but the spark ring is of the type that in Patterson/Casica book, that is listed as an unknown manufacturer. I will attach a photo in a bit. Thanks in advance.
Tim Moore
First Name: TIMOTHY
Last Name: MOORE
* REQUIRED* Type and Year of Model Ts owned: As many as can fit in the buildings, need to add on again.
Re: HCCT Trouble shooting
Post by Tim Moore » Mon Sep 28, 2020 10:08 pm
Scuff the ring and pointer with abrasive and set gap. Common problem I have also had.
MKossor
Last Name: Kossor
Post by MKossor » Tue Sep 29, 2020 12:26 am
Surprising but oxidation on the spark ring and/or pointer can impead or prevent arcing between electrodes. This is the first thing you should check when experiencing a coil with missing sparks before concluding the coil suffers from irreparable internal arcing. Any good handbook HCCT operation should cover this fundamental operating detail.
BE_ZERO_BE
First Name: BOB
Last Name: CASCISA
Post by BE_ZERO_BE » Tue Sep 29, 2020 3:38 am
5.10
Respectfully Submitted,
Be_Zero_Be
Andy Loso
First Name: Andy
Last Name: Loso
Post by Andy Loso » Tue Sep 29, 2020 7:50 am
I have glass beaded the ring, pointer, and the socket the pointer installs into. Check out the photo.
jab35
Last Name: Bartsch
Post by jab35 » Tue Sep 29, 2020 10:23 am
Have you verified the Ford coil being tested is fully functional? If so, have you checked the 'spark' circuit, the ring to frame insulation, and the ring to coil secondary connection? And the coil box bronze spring terminals and wiring connections. Thanks for sharing photos, you will have this fixed in no time, jb
Ron Patterson
Post by Ron Patterson » Tue Sep 29, 2020 11:39 am
Andy
Give me a call.
Your problem is common to this particular type HCCT.
Ron Patterson
namdc3
First Name: Nikolaus
Last Name: Martin
Post by namdc3 » Tue Sep 29, 2020 1:22 pm
Andy, it is an Service Station Equipment Company (SSECO) unit, as well - just a later version than shown in the HCCT handbook SSECO section. It appears your spark ring might be grounded to the frame via the two mounting bolts. That needs to be isolated electrically, preferably by standoffs that don't have a through hole.
J1MGOLDEN
Last Name: Golden
Post by J1MGOLDEN » Tue Sep 29, 2020 3:46 pm
Congratulations Andy!
You have identified the Service Station Equipment Hand Crank Coil Tester displayed on Page 63, as an unknown manufacturer, in the HCCT Handbook, by Bob Cascisa and Ron Patterson and that was the one I had the most trouble with, at the time.
I still have that heavy coil ring, as I replaced it with an Allen Coil ring that Ron had available.
Andy Loso
First Name: Andy
Last Name: Loso
Post by Andy Loso » Sun Oct 04, 2020 8:58 pm
I have it figured out. With some good private messages, several emails, and a chit chat with the Coilman, the solution was found. The spark ring was grounded to the frame. I made some new standoffs out of some delrin, making sure there was no thru hole. One side holds the delrin to the frame and the other held the spark ring to the delrin. Now I can finish the restoration. I'll post a photo when done.
Thanks again.
Post by RajoRacer » Sun Oct 04, 2020 10:30 pm
I turned Delrin stand-offs for my Standard HCCT - worked perfect.
