This is a manifold built by The Economy Manifold Co, Pat. Applied For, Syracuse, NY
Does any one have any history and why it was designed this way?
"Inquiring minds want to know..."
Manifold Identification
Mark Chaffin
- Last Name: Chaffin
Re: Manifold Identification
That is a manifold with a heating jacket cast around it. The idea was to heat the cold air fuel mixture as it passes through the manifold and enters the engine. Neat item. Similar to the RAJO. I would be interested in buying it if you want to sell it.
JW21TT
- First Name: Jim
- Last Name: Williams
- * REQUIRED* Type and Year of Model Ts owned: 1921 TT Wrecker 1920 TT Tanker
- Board Member Since: 2012
Paul
I also have a manifold made in Syracuse my its called the perfect manifold .
Made by the perfect manifold company Syracuse ny
I have never seen another like yours or mine.
[image][/image]
[image][/image]
- Attachments
- image.jpeg (36.67 KiB) Viewed 2090 times
- image.jpeg (33.86 KiB) Viewed 2090 times
This post didn't seem to get much clarification. Perhaps someone will have the information you are looking for this time.
http://www.mtfca.com/discus/messages/70 ... 1502068617
Found this ad for the Economy Manifold - no luck on the Perfect
