Can anyone confirm that the screws that hold on the door glass trim are #8 fine thread? I’m finally installing the glass channels and glass in my doors and the screws seem a little loose. I’m hoping they don’t need to be retapped larger.
Brad
Closed Cab TT Question
- Last Name: Kelly
Re: Closed Cab TT Question
I'll check my '25 TT and get back to you this evening.
- Last Name: Kelly
My TT uses a fine 32TPI screw.
- First Name: Herbert
- Last Name: Palmer
- * REQUIRED* Type and Year of Model Ts owned: 1924 Snowmobile,1923 Touring,1914 Roadster,1920 TT,1927 C-cab,1925 TT
My TT also has Oval Head Slotted 10-32 3/4 inch machine screws.
- Last Name: Williams
- * REQUIRED* Type and Year of Model Ts owned: 1923 TT truck
I got 10 32 oval head slotted screws from Fastenere. $11.30 for 25 screws. They’re 1 1/4 inches long. Don’t stock 3/4, but they’re easy to cut off. Went through the same question about 8 32 screws. Too loose.
Topic author - Posts: 625
- First Name: Brad
- Last Name: Kirtner
- * REQUIRED* Type and Year of Model Ts owned: 1924 Touring Car, 1927 Closed Cab TT, 1927 Coupe
10-32 is the trick. Picked up some Phillips heads from the Big box store so I can button up the door until I can get to the local hardware to get the oval flat heads. Thanks guys!
Brad
Brad
