Member information block at the right
Topic author - Posts: 1685
- First Name: Dennis
- Last Name: Seth
How do you post a picture of your car in the member information block at the right side of the post?
- Last Name: Strange
Re: Member information block at the right
Click on your username in the upper right. Select "user control panel". One of the options will be to add an Avatar. Be aware that the picture you select to be your Avatar must be shrunk down to no more than 90 pixels high and wide.
RustyFords
- First Name: Don
- Last Name: Allen
- Last Name: Seth
Being that I am totally computer ignorant what is "Avatar" and do I have to download a special program to use it?
RustyFords
- First Name: Don
- Last Name: Allen
It's the little photo like I have at the right of the screen.perry kete wrote: ↑Sun Jan 06, 2019 12:13 pmBeing that I am totally computer ignorant what is "Avatar" and do I have to download a special program to use it?
1924 Touring
Maximum dimensions; width: 90 pixels, height: 90 pixels, file size: 21.00 KiB.
I tried it but by time I got it down to 90X90 it was still 36+ KB and no longer in focus. I was going to wait till the dust settles and send a note to Chris to see it it could be changed.
Click on you name, when the window opens you will see edit profile after your name, click that. In the new window that opens the profile tab will be open, edit avatar is in the drop down on the left, click on it.
- Last Name: Seth
Thanks everyone I got it!
WOW! it even added my photo to all the old posts where I was asking how to add it!
Mark, I think you need to start with a full size photo. I picked one 3468 pixels wide where the car filled a lot of the picture. I made a copy and cropped it to cut out most of the stuff on either side of the car. That left me with a picture 1560 pixels wide, which I resized to 90. That tiny size can't show any detail no matter what you do, but I think starting with the biggest original file you can find will get it as good as it's going to get. I started with this.
RustyFords
- First Name: Don
- Last Name: Allen
You nailed it Steve.
Starting with the highest resolution photo possible is the key to a clear Avatar photo.
1924 Touring
John Warren
- Last Name: Warren
I started with an iphone photo, put it into paint, stretch skew to 20% , saved that then did it again to 90%. Sure is small
- Last Name: Juhl
When resizing a photo to 90 pixels, reduce the largest dimension to 90 and let the other fall where it may.... Usually there is a command like "constrain proportions." If you don't do so, your photo may end up out of proportion.
Ruxstel24
- Last Name: Hanlon
The birthday year starts at 1919...
I hope we aren't slighting anyone over 100 !
