removing engine from a 15 roadster
mike37 cdn
First Name: mike
Last Name: mclean
Post by mike37 cdn » Tue Nov 03, 2020 6:04 pm
hi all I am removing the engine from a 15 roadster do I have to raise the body to get the engine out or anything else that i have to remove to get it out thanks for the help mike
Michael Peternell
First Name: Michael
Last Name: Peternell
Re: removing engine from a 15 roadster
Post by Michael Peternell » Tue Nov 03, 2020 7:02 pm
If the firewall is the same as a touring you will. The pan ears won't clear it. I believe there's another post discussing the same thing.
NealW
First Name: Neal
Last Name: Willford
Post by NealW » Tue Nov 03, 2020 7:03 pm
I had to raise the body on my 15 runabout. I left the rear two body bolts installed but loose so that I could lift the body up at the firewall without having it to slide back while lifting it.
Michael Peternell
First Name: Michael
Post by Michael Peternell » Tue Nov 03, 2020 7:19 pm
Don't over think the "lift". A good pry bar and two 3/4" pieces of wood and two pieces of 1 3/4" wood. Neal's advice is spot on!
Post by RajoRacer » Tue Nov 03, 2020 7:20 pm
Saws-All ?
Last Name: Wrenn
Post by TWrenn » Tue Nov 03, 2020 7:26 pm
I'm with Rajo...when I took the engine out of my '15 touring I just performed some minor surgery on the firewall to
slide the engine out. No big deal. Why go to all the trouble raising the body, risking busting things, when you don't have to.
Michael Peternell
First Name: Michael
Post by Michael Peternell » Tue Nov 03, 2020 10:19 pm
Oh gosh! Please don't! It took me a good part of a day the first time. A few weeks later only a couple hours.
AndreFordT
First Name: Andre
Last Name: Valkenaers
Post by AndreFordT » Wed Nov 04, 2020 12:11 am
I just took the firewall out on the 1915 and did the same on the 1913.
Andre
Belgium
Last Name: Wrenn
Post by TWrenn » Wed Nov 04, 2020 10:04 am
Andre...how coincidental! I did the same too on my 15 and 13. I did forget to mention in my previous post that while I didn't take the '15s firewall completely off, I just slid it up a few inches, but still had to perform a little body surgery to get the pan ears out. IT wasn't all that bad, nothing showed when I was done.
But man the '13 and my '12 for that matter, was a whole lot easier without that big wood firewall in the way! An easy, almost horizontal pull out/drop in!!
Post by RajoRacer » Wed Nov 04, 2020 10:34 am
I currently own a '14 Touring which I had modified years ago to electric start for the previous owner - he was in his mid 80's and couldn't hand crank any longer. I removed the firewall and as Tim stated "but still had to perform a little body surgery to get the pan ears out", I did the same to be able to remove the starter.
Post by Steve Jelf » Wed Nov 04, 2020 10:37 am
Neal is correct. You don't have to remove the firewall or attack it with a Sawzall. Just undo the brackets from the frame, remove the front four body bolts, loosen the rear two, and put the front of the body on 2 x 4 blocks. I've done this several times, and I've never broken anything. I don't see anything to break.
