If I'm in error, please let me know when and where these changes (if any) occur and I will add them to this drawing (if they're not more than a small change to a part or two) or make a new drawing for the other year span if they're a bit more complex...but I don't honestly think there are any other than maybe that 8 sided keyed washer on the tail end of the worm being round rather than the 8 sided one, because I've seen one like that. If that's a later model part, let me know and I'll add it to this drawing with a reference to the year it was used. Also I know that some folks have put shims between the thrust bearing and the Hyatt bearing sleeve, but since I could find no part number for that shim (or thickness), I've left it off. If any of you guys knows what that number may be, please let me know so I can add it also.
Normally I wouldn't include the spring perch on the rear axle assembly, but it seemed necessary to have something that bolted that bloody backing plate to the axle housing, otherwise it would just be sitting out there with nothing to hold it to the housing. It seemed the best choice, since the radius rods go with the Drive Shaft Assembly and the brake pivot and brake expander go with the Brake Assembly.
