will pancake hasslers bolt to the rear of a big drum ruxtel
warwick_preval
First Name: warwick
Last Name: preval
* REQUIRED* Type and Year of Model Ts owned: 25 tr 22 coupe
Board Member Since: 2014
Post by warwick_preval » Mon Feb 25, 2019 5:21 am
Hi all will Hassler shocks bolt to a 26/7 big drum Ruxtel with( Rocky mountain brakes) so i can match the front hasslers on my 22 coupe cheers Warwick.
Re: will pancake hasslers bolt to the rear of a big drum ruxtel
Post by RajoRacer » Mon Feb 25, 2019 10:50 am
The older beehive style will not - shock mount to brake band conflict unless the mount base is "shimmed" out - can't comment on pancake style as I've not mounted any BUT the rear mount is quite different.
TonyB
First Name: Tony
Last Name: Bowker
Post by TonyB » Mon Feb 25, 2019 11:11 am
I remember reading that cannot use Hasslers with the RM brakes because of interference.
If the original Hasslers would not fit the large drum rear end, it seems very likely that they would be redesigned for the 26/7 brake drum. Someone must know......
Tony Bowker
La Mesa, California
Kohnke Rebabbitting
First Name: Herman
Last Name: Kohnke
* REQUIRED* Type and Year of Model Ts owned: 1914 Roadster, 1922 Coupe
Post by Kohnke Rebabbitting » Wed Feb 27, 2019 12:35 am
The Pancake style were made especially for the 26-27's.
The fronts will fit all, but the rears only the large drum.
Herm.
Wilbur
First Name: Wilbur
Last Name: Swearingin
* REQUIRED* Type and Year of Model Ts owned: 1923 Runabout 1923 Coupe 1924 Tudor 1926 Pickup
Post by Wilbur » Wed Feb 27, 2019 6:38 pm
i have pancake Hasslers both front and rear on my 1924 Tudor with a Ruckstell rear axel. Just installed the new AC brakes. All fits and works well.
