KW Instructions in lid.
Post by Original Smith » Sun Nov 22, 2020 2:37 pm
Rich Bingham
First Name: Rich
Last Name: Bingham
Re: KW Instructions in lid.
Post by Rich Bingham » Sun Nov 22, 2020 4:25 pm
Dang ! Wrong lid, no instructions - I'm in a bad way !
"Get a horse !"
John Warren
Last Name: Warren
Post by John Warren » Mon Nov 23, 2020 7:08 am
That is in, in-creditable condition, can you re-produce the label? Thanks for sharing.
Post by Original Smith » Mon Nov 23, 2020 10:49 am
I believe R.V. has them.
Brent Mize
First Name: Brent
Last Name: Mize
* REQUIRED* Type and Year of Model Ts owned: 1927 Sport Touring & 1927 Sport Runabout
Post by Brent Mize » Mon Nov 23, 2020 2:43 pm
I’m lucky enough too to have an original label in mine.
Here’s my coils and box. I restored the coils and switch.
I used black oxide on the tops.
I purchased the coil box mostly done, but the switch needed some help and the coils did as well.Very satisfying project.
I did use new snap catches that RV makes. They are beautiful.
Post by Original Smith » Tue Nov 24, 2020 10:10 am
Brent, I find your accessory carburetor knob interesting. Never have seen one of those.
Post by Jerry VanOoteghem » Tue Nov 24, 2020 10:53 am
Are these the coils with dimensions unique to the '13 boxes?
Brent Mize
First Name: Brent
Last Name: Mize
Post by Brent Mize » Wed Nov 25, 2020 9:28 am
Yes, these coils are very similar in size to earlier coils.
The terminals are also located differently than later KW coils.
Post by Original Smith » Wed Nov 25, 2020 10:21 am
These coils only fit the 1913 KW coil boxes. For some reason, they seem to work more often than the later ones. Brent does the most beautiful job restoring these. I don't bother, because once in the box, you can't see them! I'm going to have to talk to Brent one day on how he does such a great job on the switch plates!
Post by TXGOAT2 » Thu Dec 01, 2022 3:44 am
Goat gesso.
Post by Original Smith » Thu Dec 01, 2022 10:05 am
I have a friend working on the instructions. Don't know when they will be done.
Mark Nunn
Last Name: Nunn
Post by Mark Nunn » Thu Dec 01, 2022 1:13 pm
I have a K-W master vibrator on the shelf with its original paper instructions under the lid. I can make that available if anyone wants to reproduce it.
Luke
First Name: Luke
Last Name: P
* REQUIRED* Type and Year of Model Ts owned: 1926
Post by Luke » Thu Dec 01, 2022 2:12 pm
I've just finished digitally restoring some 180 year old botanical drawings (along with translating many pages of French and Latin!) so should be able to manage some 100 year old instructions if someone wanted to send me a good photograph of them.
By a good photograph I mean one of reasonably high resolution, even illumination, with no shake and in focus. I can then clean and touch up as needed, and return an image that could be used for printing by anyone that needs it. After that it'd be up to you if you want to 'age' the result with yellow paper or stain it with old tea (or something worse :), but at least you'd be able to start with something similar to how they'd have been when new...
Luke.
UPDATE: Didn't see Mark's post until finishing mine, have sent a PM.
Mark Nunn
Last Name: Nunn
Post by Mark Nunn » Fri Dec 02, 2022 8:07 am
Luke, I will send an email to you with scans. This is my master vibrator.
