What have you done with your T in December
NU2theT
Last Name: Wendt
Post by NU2theT » Tue Dec 01, 2020 8:56 pm
Well ladies and gentlemen the last month of a year I'm sure we won't ever forget.
Got the new front spring and shackles together, waiting for the paint to dry on various parts and the spring clip bar. Will get in a few more miles on before setting up for winter and digging into band replacement.
Aussie16
First Name: Warwick
Last Name: Landy
Re: What have you done with your T in December
Post by Aussie16 » Wed Dec 02, 2020 1:06 am
Went to the Christmas tree farm in the T pickup to pick up this years tree. Merry Christmas to everyone here at the forum.
Roffe
First Name: Rolf
Last Name: Oehman
Post by Roffe » Thu Dec 03, 2020 5:02 am
Beautiful car and photo Warwick.
Post by Steve Jelf » Fri Dec 04, 2020 12:30 am
After several weeks of doing other things (cutting & splitting firewood, cleaning up storm damage, planting trees, etc.) today I got back to work on my mag ring.
Applying Kaptan insulating tape to copper ribbons. I put it on both sides. It's 1 mil, so the winding has 2 mils of insulation between layers.
Winding a coil. It took awhile to figure out how to tie a finished coil with wire so it won't unwind.
Four down, 28 to go.
Tim Rogers
Last Name: Rogers
Post by Tim Rogers » Fri Dec 04, 2020 8:39 am
So when can we start sending you our mag ring cores for rebuilding?
AndreFordT
First Name: Andre
Last Name: Valkenaers
Post by AndreFordT » Fri Dec 04, 2020 8:59 am
Waiting for some parts this week so I rebuided a few coils.
Andre
Belgium
AndreFordT
First Name: Andre
Post by AndreFordT » Fri Dec 04, 2020 9:09 am
Steve, fine to see you back on the coilring.
You can use a 3/8 wide tape to block the end of each coil.
Don't forget to insulate the side of the coils at the place you plie over the strip to make the connection part of each coil.
Good luck
Andre
Belgium
Post by Steve Jelf » Fri Dec 04, 2020 11:34 am
I'll leave that to Andre and RV and others. I hardly ever finish anything as it is. I don't need to take on anything new. :D
Last Name: Wrenn
Post by TWrenn » Fri Dec 04, 2020 1:37 pm
Stored them! :(
Ken Lefeber
First Name: Ken
Last Name: Lefeber
Post by Ken Lefeber » Sun Dec 06, 2020 6:26 pm
Celebrated Wilma's 94th birthday with a short ride to the recently opened Johnsonville Marketplace.
jachady
Last Name: Chady
* REQUIRED* Type and Year of Model Ts owned: 1924 Fordor
Post by jachady » Sun Dec 06, 2020 9:55 pm
Spent an evening chasing a sunset.
ABoer
First Name: Anthonie
Last Name: Boer
* REQUIRED* Type and Year of Model Ts owned: 1912 touring 1923 roadster 1925 pickup
Post by ABoer » Mon Dec 07, 2020 7:14 am
This morning I put new pistons in a friends engine , and mount the coilring and flywheel.
Toon
ABoer
Last Name: Boer
Post by ABoer » Mon Dec 07, 2020 8:29 am
And the Magneto is working OK
Toon
Corey Walker
First Name: Corey
Last Name: Walker
Post by Corey Walker » Mon Dec 07, 2020 6:18 pm
I did the last bit of disassembly on my rear axle. I was putting it off because I didn’t have a sleeve puller but I made one.
ryanf1023
First Name: Ryan
Last Name: Fenrich
* REQUIRED* Type and Year of Model Ts owned: Speedster Project
Post by ryanf1023 » Mon Dec 07, 2020 10:21 pm
I finally began cleaning up my field coil rings. The apparatus is a little crude, but it works just fine.
15 more to go.
WayneJ
Last Name: Jorgensen
Post by WayneJ » Thu Dec 10, 2020 1:10 pm
It was 50 degrees and sunny yesterday in Batavia, IL, so ....
I was able to give the T a little exercise. Started on the 2nd pull.
Wayne Jorgensen, Batavia, IL
1918 Runabout
henryford2
First Name: Joseph
Last Name: Andulics
Post by henryford2 » Thu Dec 10, 2020 4:38 pm
Started freehand lettering (with patina) the truck. Enjoy
John Codman
Last Name: Codman
Post by John Codman » Thu Dec 10, 2020 5:13 pm
Started on the job of adjusting the clutch screws. The floormat is out, as are the front floorboards. The transmission top cover is off and the left rear wheel is jacked up. I'm hoping that in the next couple of days I will pull the spark plugs, then I'll have a go at actually doing he adjustment. Tomorrow is a birthday party for an old friend who is moving a couple of hundred miles away, so probably no progress until Saturday.
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Thu Dec 10, 2020 5:22 pm
Got to get the boat done! Oh.., it will be towed behind a 1927 RPU on a period correct trailer and 1926 Johnson outboard. It only weighs about 90 lbs, White Cypress.
Priorities Man!
Hank
dmdeaton
First Name: Danny
Last Name: Deaton
Post by dmdeaton » Thu Dec 10, 2020 6:50 pm
Got my small tanks filled so I can rivet Saturday
NU2theT
Last Name: Wendt
Post by NU2theT » Sat Dec 12, 2020 7:31 pm
Priorities Man!
Hank
That is cool Hank, post some pictures of that Johnson. I acquired a 25 last year, these are pretty rare indeed.
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Sat Dec 12, 2020 7:51 pm
Here you go Scott!
Johnson catalog 1926 cover.jpeg (103.11 KiB) Viewed 9309 times
TonyB
First Name: Tony
Last Name: Bowker
Post by TonyB » Sat Dec 12, 2020 9:59 pm
Absolutely nothing☹️
I’ve been working on my new (to me) house. Sanded the floors, some new drywall and refurbished the kitchen cabinets.
New kitchen
New kitchen
New patio door and new floor
I hope to move all the stuff in the workshop after the house move and resume T work in February.
Tony Bowker
La Mesa, California
Michael Peternell
First Name: Michael
Last Name: Peternell
Post by Michael Peternell » Sat Dec 12, 2020 10:46 pm
Here you go Scott!
And a picture of the elves you have working in the shop. You are a busy sum bitch!
NU2theT
Last Name: Wendt
Post by NU2theT » Sun Dec 13, 2020 9:52 am
Hank that is outboard eye candy, I will stop procrastinating on mine and give it some shine. I also have the brass lower prop and tank needs the fresh paint and decals.
Thanks for posting the pictures and love those old adds.
John Codman
Last Name: Codman
Post by John Codman » Sun Dec 13, 2020 5:25 pm
Henry, I love those old wooden boats! Also modern replicas of them.
Post by Norman Kling » Sun Dec 13, 2020 9:15 pm
I haven't worked on any of mine, however, am installing a new top on a 1920 owned by a member of our club. The hardest part is done. The bows have been wooded and pads installed with alignment of the bows. The windbreaker and rear panel are installed. Next, when we have another warm day, will be the top itself. Here at this time of year, we can go from rain, fog, hail, wind or warm sunshine. Some days get into the 70's and 80's. In 46 years we have lived here we have only had about an inch of snow a few times, usually if it is cold, there might be a few snowflakes mixed with light rain. We got some autumn leaves, but the next day the wind came up and blew them all away. About 2 weeks ago the wind got so strong it split a large Oak so I also have a lot of wood to cut up and maybe enough firewood for several years! So I work on the T when my knees and back are not bothering me. I try to do a few hours work each day but vary it from day to day. Sometimes raking leaves. After it rains there will also be weeds to cut and in winter some trees to prune. Anyway, when the top is on, the T will be almost ready to go home.
Art Ebeling
First Name: Art
Last Name: Ebeling
Post by Art Ebeling » Mon Dec 14, 2020 7:19 am
I am making the best of a fourteen day Covid quarantine and installed the fenders and hood. I still have to paint the correct fender bolts and screw the hood former to the firewall. I have thirteen days left so I am stretching it out. Art
rnkugel
First Name: Reuben
Last Name: Kugel
* REQUIRED* Type and Year of Model Ts owned: 1915 Touring 1926 RAJO Speedster
Post by rnkugel » Mon Dec 14, 2020 10:12 am
Got new E-brake linings on the speedster. Pulled the carb of the 15 Touring to discover that the float was set about an 1/8" to high. reset to 1/4". Also discovered there was no gasket between float bowl and carb body. Glad I had one. Carb reinstalled back on car. Now in the middle of rewiring the entire 15 Touring. Long winters hear in Wisconsin are a great time for some tinkering.
1915 Touring
1926 RAJO Speedster
John_Aldrich
Last Name: Aldrich
* REQUIRED* Type and Year of Model Ts owned: 1915, 1923. 1927
Post by John_Aldrich » Mon Dec 14, 2020 5:34 pm
In the "parts gathering" mode so a buddy of mine and I can build a Depot Hack.
John Aldrich
Typical Model T Addict
John Warren
Last Name: Warren
Post by John Warren » Mon Dec 14, 2020 6:25 pm
Nice Boat and motor, Hank. You are a man of many talents. SUPER JOB. thanks for sharing jw
MKossor
Last Name: Kossor
Post by MKossor » Wed Dec 16, 2020 9:22 pm
Busy working in Santa's Model T work shop; he knows who's been naughty (?) and Nice. Better be good for goodness sake!
Happy Holidays!
Post by Allan » Wed Dec 16, 2020 10:14 pm
I had two days of city driving on promotion work for Haigh's chocolates. Yum. Second day out, the Holley H1 resumed it's leaking when I stopped the van outside a couple of the stores. Then it decided to behave itself for the rest of the day.
I might finally have to fit one of Stan's H1 rebuilt carbs that looks too good to get dirty. At the same time, I can fit another alloy manifold which has no welding repairs and fix an exhaust manifold leak.
Angmar
Last Name: Bailey
Post by Angmar » Sun Dec 20, 2020 7:50 pm
Attended a Christmas "Covid" parade for the town. People could watch safely as the cars drove past their homes. Lots of fun but dang cold.
Still crankin old iron
NealW
First Name: Neal
Last Name: Willford
Post by NealW » Sun Dec 20, 2020 8:53 pm
When you have temperatures in the mid 50's in December, you take advantage of it! Our 15 runabout sits low enough with the top up that I can get it out of the garage with the top up with 2" to spare. Our 21 touring is a few inches taller and requires the top down before backing out, or it will be a bad day. When it is time for a quick spin, it's never much of a choice which one I take!
Angmar
Last Name: Bailey
Post by Angmar » Sun Dec 20, 2020 9:16 pm
Fantastic car Neil and what a clean garage....
Post by Mark Gregush » Sun Dec 20, 2020 10:55 pm
Redid 5 coils, 4 with new points 5th is waiting. When I sold the 1921 huckster all my working coils went with it. Just finished up regapping the vibrators on the 4, need to check now on the HCCT. Can't drive the 25 without them! Got a Craftsman tilting head band saw yesterday. Need to get carbon paper to start make patterns so I can rewood it. Don't want to cut the plans up.
Mark Nunn
Last Name: Nunn
Post by Mark Nunn » Mon Dec 21, 2020 8:44 am
I removed and disassembled my front axle and spindles. I boxed them up to send out for repair and bushings. I'm waiting until after the shipping companies get caught up before send them out. I have one inner bearing race that can spin in the hub. I'll need to address that when parts arrive.
dmdeaton
First Name: Danny
Last Name: Deaton
Post by dmdeaton » Mon Dec 21, 2020 8:49 am
I spent all day yesterday trying to find these two items
I found them after giving up twice
varmint
First Name: Vernon
Last Name: Worley
Post by varmint » Fri Dec 25, 2020 10:24 am
2020 has been interesting, haven't had much time for the Model T. On the pickup had an engine wear out at 250k miles so rebuilt an engine and its transmission had a failed torque converter. So, got one from the junkyard, rebuilt it and installed at the same time as the engine. Wife's car had a flat tire and was returning from the tire store when the transmission on it gave out completely, coasting home. Back to the junkyard for a transmission. Lost two relatives this year, one to COVID. But we still have each other and our jobs. Overall, I enjoyed this challenging year and we finally got the floor welded to the body.
1926 Coupe floor weld
Vern (Vieux Carre)
John Codman
Last Name: Codman
Post by John Codman » Fri Dec 25, 2020 11:20 am
I always enjoy reading this monthly post. I am constantly amazed at the talent that I see here. This is an amazing group. Merry Christmas to all!
First Name: Dallas
Last Name: Landers
Post by Dallas Landers » Tue Dec 29, 2020 3:51 pm
Finished up the 27 for a friend.
Moved the RPU into the new shop and started the RM brake install.
Discovered I dont need to fight wire or zip ties to change the brake peddle. The visegrips worked great.
