throttle linkage mod on 27 engine block
Cadjin dex
First Name: Dex
Last Name: Doucet
* REQUIRED* Type and Year of Model Ts owned: Runabout
Post by Cadjin dex » Tue Dec 01, 2020 5:23 pm
I need to run my throttle rod through the cylinders but the casting webbing is solid there. However there is a recessed portion about 1" squared that seems like it was made to be easily knocked out.. can I drill through it or drill and chisel that area to pass my throttle rod? Is this something yall are familiar with?? Thanks.
Re: throttle linkage mod on 27 engine block
Post by Rich Eagle » Tue Dec 01, 2020 5:50 pm
They talked about it here.
http://www.mtfca.com/discus/messages/29 ... 1188341007
Maybe there is better info.
Cadjin dex
First Name: Dex
Last Name: Doucet
Post by Cadjin dex » Tue Dec 01, 2020 6:00 pm
Thanks Rich.
ModelTWoods
First Name: Terry
Last Name: Woods
Post by ModelTWoods » Thu Dec 03, 2020 12:00 am
If I were doing it, I would definitely drill as opposed to using a hammer and chisel. I would cry for days if I send a crack in a direction that wasn't intended.
Last Name: House
Post by George House » Thu Dec 03, 2020 6:08 am
Do you still have the correct solid valve cover panel ? If so you’ll want to deface a hole in the middle of it too. ... #vaporizers
Charlie B in N.J.
First Name: CHARLIE
Last Name: BRANCA
Board Member Since: 2010
Post by Charlie B in N.J. » Thu Dec 03, 2020 7:01 am
I did my ‘27 Tudor years back. The block had the hole and so did the valve cover but the cover gasket didn’t.
John.Zibell
Last Name: Zibell
Post by John.Zibell » Thu Dec 03, 2020 9:09 am
Lang's sells a kit so you don't need the hole in the block. https://www.modeltford.com/item/6299CL.aspx
1926 Tudor
John Warren
Last Name: Warren
Post by John Warren » Thu Dec 03, 2020 10:30 am
I would not open the block and valve cover! You have a sealed engine with a proper breather. The most of us have an open engine with the valve cover and block open to the elements. That is one of the reasons that I like the 2 valve cover engines. I did a mod on a couple of engines sealing them with a piece of tubing connecting the block hole with the valve cover hole. It works to seal the engine back up. I would, definitely, in your case consider the linkage option.
George Hand
Last Name: Hand
Post by George Hand » Thu Dec 03, 2020 10:58 am
The throttle bracket makes the most sense to me, no molesting of the original block or "valve door" & not having to relocate the small lever on the throttle rod. George
Last Name: House
Post by George House » Thu Dec 03, 2020 12:48 pm
Amen... other George
