Kingston Coil Works
AndreFordT
First Name: Andre
Last Name: Valkenaers
Kingston Coil Works
Post by AndreFordT » Thu Dec 03, 2020 11:54 pm
Sometime ago I posted a few questions about the setting and the repair of a few (4) Kingston Coils.
In the attachement a few photos of the job on the coils.
Two of the four get other high tension coils. There for I took good coils out of regular FORD coil with bad wood.
All four coil get new points and new capacitors.
Current settings on my HCCT give the best result between 0.8Amp and 1.00Amp gap of the spark is 5/16". The start tension is 0.6Vac.
Setting lower the gap is only 1/8", setting higher the start tension is about 2.0Vac and there was no constant spark.
Take care.
Andre
Belgium
As they arrived here
As they are now a live and kicking
AndreFordT
First Name: Andre
Re: Kingston Coil Works
Post by AndreFordT » Fri Dec 04, 2020 8:55 am
Final photos.
Andre
Belgium
Post by Mark Gregush » Fri Dec 04, 2020 9:23 am
I have some Hinze that I am thinking about swapping out the primary and secondaries for the 1914 up style, may also use the newer style points. Nice work.
Quickm007
First Name: Mario
Last Name: Brossard
Post by Quickm007 » Fri Dec 04, 2020 9:44 am
Amazing work André. Well done!
Super Mario Bross ;)
1911 Touring
1914 Speedster
