Same size?
blgitn
Topic author - Posts: 147
- First Name: Roger
- Last Name: Harmon
Same size?
Are the outer front wheel bearing and the camshaft nut the same size?I
R/ Roger.
R/ Roger.
Re: Same size?
I thought I knew, but it took awhile to find a camshaft and check. The answer is no. The camshaft nut is loose on a spindle. Of course the two nuts are completely different shapes, too.
Re: Same size?
Not only are the nuts a different size, but the nut on the spindle has castles on it for cotter pin and the right nut has an opposite thread.
Re: Same size?
If you are asking what size wrench it takes, I would have to check. I do know the cam gear lock nut would use the same size spark plug wrench as the Model A spark plugs. Also, the cam nut is part of the front seal, the seal rides on it and is also the spacer for the rotor or gear on a distributor setup.
BE_ZERO_BE
- First Name: BOB
- Last Name: CASCISA
Re: Same size?
Here is a tool I made from a Model T wheel wrench.
It fits the front bearing and the camshaft nut.
Respectfully Submitted,
Be_Zero_Be
Be_Zero_Be
Re: Same size?
Bob I think you may be the only one that read the question correctly.
I misread it. Great tool.
Re: Same size?
Steve Coniff has a Snap On socket for the camshaft nut. I've not seen another.
Re: Same size?
If everybody else read it incorrectly, maybe it was unclear.
This is what I made for the timing gear nut.
Re: Same size?
BE_ZERO_BE wrote: ↑Tue Dec 08, 2020 12:05 pmHere is a tool I made from a Model T wheel wrench.
I believe the other tool shown is a beer bottle wrench, is it not?
Nice job on the cam nut socket!!
BE_ZERO_BE
- First Name: BOB
Re: Same size?
There is a Snap-On socket on eBay right now.
https://www.ebay.com/itm/SNAP-ON-36-F-S ... 4098385276
I have one as well but they are not deep enough to use on the spindle bearing.
Be_Zero_Be
Be_Zero_Be
Re: Same size?
...they are not deep enough to use on the spindle bearing.
I think it would be pretty easy to make a socket for that, but #1349 is good enough.
Re: Same size?
There is a Z tool for the camshaft nut. I have an early version, T2333. Like the flywheel wrench, it has a real dogleg offset, which causes both tools to crank off the nut well before they are properly tight. This damages the nut and the wrench.
On the camshaft nut I keep the wrench in place by slipping a big washer over the neck on the nut, a tubular sleeve next, and another washer up to which the roller timer nut is wound. This stops the wrench cranking off the cam nut.
