Drilling steel?
ivaldes1
First Name: Ignacio
Last Name: Valdes
Drilling steel?
Post by ivaldes1 » Sat Dec 12, 2020 3:11 pm
Using a commonly available titanium bit I am able to make very little progress drilling the pictured hole for the front fender hanger. Is there a better way?
Kerry
Last Name: van Ekeren
Re: Drilling steel?
Post by Kerry » Sat Dec 12, 2020 3:25 pm
Start with a small drill bit and then a few in-between sizes up to your final size.
David Mazza
First Name: David
Last Name: Mazza
* REQUIRED* Type and Year of Model Ts owned: 1925 t runabout
Re: Drilling steel?
Post by David Mazza » Sat Dec 12, 2020 3:26 pm
Dewalt or Milwaukee high speed steel bit. Few bucks more but I was able to get through 16 3/8 diameter 1/4” thick holes through steel before killing drill bit. The titanium bits are hit and mis. Also Irwin bits suck hard too.
Re: Drilling steel?
Post by Jerry VanOoteghem » Sat Dec 12, 2020 4:49 pm
David hit on it. Too much Chinese junk in the drill market these days. To my thinking, the "titanium" drills have a "gee whiz" coating to distract from the fact that most are junk. Mind you, a well made drill, with real titanium nitride coating, is a fine tool. But, those don't come cheap!
Virtus
First Name: Paul
Last Name: Robertson
* REQUIRED* Type and Year of Model Ts owned: Ford model tt 1921 right hand drive
Re: Drilling steel?
Post by Virtus » Sat Dec 12, 2020 4:49 pm
As Kerry says, start with a small size bit. Set the drill at very low revs and ideally use tungsten carbide bits.
Re: Drilling steel?
Post by Jerry VanOoteghem » Sat Dec 12, 2020 4:50 pm
Some cutting oil wouldn't hurt either.
Jeff Hood
Last Name: Hood
* REQUIRED* Type and Year of Model Ts owned: 1915 Touring, 1923 Fordor, 1924 Martin Parry Canopy Express, 1925 Coupe
Re: Drilling steel?
Post by Jeff Hood » Sat Dec 12, 2020 5:39 pm
Go slow. The larger the bit, the slower the speed. I have watched lots of guys run a 1/2 inch bit at full drill motor speed and cuss and swear as the bit smoked and turned blue as it overheated and dulled. Slower speed, cutting oil, and some pressure against it will cut many holes.
Re: Drilling steel?
Post by Allan » Sat Dec 12, 2020 7:22 pm
I'll third the start small vote. Use your 3/8" drill to make a centre, then come at the hole in two or three steps. There's much less load required, and each drill is making a smaller cut.
D Stroud
First Name: David
Last Name: Stroud
Board Member Since: 2011
Re: Drilling steel?
Post by D Stroud » Sat Dec 12, 2020 8:52 pm
Check the end of the bit and make sure it is sharpened correctly. I have seen several of those bits that were sharpened "backwards", the angle was ground the wrong direction. Those don't work too well. :lol: Dave
1925 mostly original coupe.
Burger in Spokane
First Name: Brent
Last Name: Burger
Board Member Since: 2014
Re: Drilling steel?
Post by Burger in Spokane » Sat Dec 12, 2020 8:55 pm
Use a plasma cutter ! :lol:
ivaldes1
First Name: Ignacio
Last Name: Valdes
Re: Drilling steel?
Post by ivaldes1 » Sat Dec 12, 2020 9:27 pm
Home Depot had 'Milwaukee Cobalt Red Helix Drill Bit Set for Drill Drivers'. It went through the frame like butter. Quite a difference. $13 for the single 3/8 inch $35 for the set. I purchased the set and hid it from my teenagers. Every project is a chance to buy a new tool. Now to figure out the bolt sizes for the front hangers.
First Name: Dallas
Last Name: Landers
Re: Drilling steel?
Post by Dallas Landers » Sat Dec 12, 2020 9:32 pm
Good drill bits are priceless.
Art M
First Name: Art
Last Name: Mirtes
Re: Drilling steel?
Post by Art M » Sat Dec 12, 2020 9:35 pm
Quite often the performance of a drill has more to do with the point geometry. Titanium coated drills usually have better geometry. I found that steam oxide coated drills work about as well as titanium drills with properly ground drills. Thinning the web really makes a big difference.
Art Mirtes
Last Name: Patrick
Re: Drilling steel?
Post by jiminbartow » Sun Dec 13, 2020 12:32 am
Dull bit. Get a “Drill Doctor” and sharpen your dull bits. Will give new life to old bits. Harden the sharpened bits by heating and quenching in oil. Jim Patrick
bobt
Last Name: Thompson
Re: Drilling steel?
Post by bobt » Sun Dec 13, 2020 6:38 am
like Jeff Hood said " GO SLOW" and push HARD. If you drill steel fast it will just burn your bit up.
Jim_PTC_GA
Last Name: Fisher
* REQUIRED* Type and Year of Model Ts owned: 1924, 1925-ish
Re: Drilling steel?
Post by Jim_PTC_GA » Sun Dec 13, 2020 6:49 am
I've experienced the same thing with different parts on my T. Some things were hard as tempered steel when logic says they shouldn't be. I've ended up using a tiny dremal type grinder more than once to resize or make a new hole.
Just give me time to Rust and I'll be good as new. :) Wabi-Sabi
Jonah D'Avella
First Name: Jonah
Last Name: D'Avella
Re: Drilling steel?
Post by Jonah D'Avella » Sun Dec 13, 2020 7:49 am
If you have one, and if it will fit, try a drill press. It will push much harder and is slower so it probably won't melt the tip as fast.
F: first F: find
O: on O: oil
R: race R: revive
D: day D: drive
Jonahdavella@gmail.com
Altair
First Name: David
Last Name: Menzies
Board Member Since: 2012
Re: Drilling steel?
Post by Altair » Sun Dec 13, 2020 12:39 pm
If a drill bit is allowed to turn in the work and not cut, it will harden the work, this is usually because the bit was not sharp in the first place and this will compound the effort and procedure.
jab35
Last Name: Bartsch
Re: Drilling steel?
Post by jab35 » Sun Dec 13, 2020 12:50 pm
Glad you were successful, I second the Milwaukee drill recommendation. I've had excellent service from their 'conventional' twist drills, which are easily hand sharpened on a fine grinding wheel without any jigs or fixtures. A sharp drill and reasonable speed and feed will produce good results.
And don't try to 'heat treat' your twist drills. HSS is inherently hard and at the same time tough, just keep them sharp. And if you have plain carbon steel drills, get a new set of HSS and' if you cannot part with the carbon steel drills, use them on wood and plastic.
StanHowe
First Name: Stan
Last Name: Howe
Re: Drilling steel?
Post by StanHowe » Sun Dec 13, 2020 4:44 pm
Absolutely the best drill bits I have ever owned or seen.
Norseman, made in Minnesota.
I have a dozen other sets and these will out drill them two to one. Hard steel, brass, whatever. Stay sharp.
There is a tool company that comes to the Great Falls swap meet every year, they sell good tools. Also a little Chinese stuff but not much. She talked me in to buying a set of these. Worth every dime.
http://www.norsemandrill.com/
StanHowe
First Name: Stan
Last Name: Howe
Re: Drilling steel?
Post by StanHowe » Mon Dec 14, 2020 5:25 pm
These:
https://www.ebay.com/itm/Norseman-29pc- ... SwImRYIgYd
$130 on ebay, might be cheaper someplace else.
By the way, I disagree with the idea of drilling progressively larger holes. Drill a small marker hole for the big bit to center in, get it turning the correct speed, douse it with some Mystic Metal Mover and drill the hole. One time. One bit. The hole will be straighter, closer to size and will not dull nearly as quickly.
Your mileage may vary, all guarantees between seller and buyer, no return without receipt, dead cockfight chickens not recommended for human consumption, etc.
Rich Bingham
First Name: Rich
Last Name: Bingham
Re: Drilling steel?
Post by Rich Bingham » Mon Dec 14, 2020 8:28 pm
I agree with Stan. Holes wander off center when haggled out progressively larger.
Also agree that you need good tooling. A lot of hardware "hobbyist" bits may work in wood, but not for the machinist. I'm a little surprised no one mentioned annealing a work-hardened piece. Another thing to watch is rate of feed, and sometimes applying a coolant/lubricant can make a big difference. MHO.
"Get a horse !"
LesAlderson
First Name: Les
Last Name: Alderson
* REQUIRED* Type and Year of Model Ts owned: 1925 TT
Re: Drilling steel?
Post by LesAlderson » Tue Dec 15, 2020 11:08 am
If you part will not fit in a drill press, use one of these.
This will give you sufficient downward pressure to quickly drill the hole.
The tool
The tool
in use
in use
Duey_C
First Name: Duane
Last Name: Cooley
Re: Drilling steel?
Post by Duey_C » Sat Dec 19, 2020 9:55 pm
I'd like to get some Norseman bits. I have a small set of Summit bits made in Montana and they're great drill bits.
Les, I didn't know someone actually made those! I've done similar when using a hand drill and a 2x4.
The others stared at me if I were deranged when setting up and accidentally looking like a genius when nonchalantly pushing down on the handle and drilling the hole. ;)
Chinese drill bits suck. Plain and simple. Under the TiN coating is pure garbanzo beans.
George Carlin mentioned the first four letters of the word garbage when talking about those beans...
I also feel dumb about never thinking of annealing a work-hardened surface.
Doc, I'm gonna ask you a silly question: Why didn't you sharpen that first bit when it wouldn't cut the mustard?
fbergski
First Name: Philip
Last Name: Berg
* REQUIRED* Type and Year of Model Ts owned: 1911 Touring 1916 Coupelet
Re: Drilling steel?
Post by fbergski » Sat Dec 19, 2020 10:04 pm
Normally I don't bring up my profession but working in Aerospace for twenty odd years, I've discovered that Cobalt drills are the best all around bits. HSS bits are junk, anything from China is junk. Solid carbide is too brittle. Carbide insert drills are fine.
Believe it or not we drill Inconel with Cobalt drill bits with great success, it's not fast but it works
ivaldes1
First Name: Ignacio
Last Name: Valdes
Re: Drilling steel?
Post by ivaldes1 » Sat Dec 19, 2020 11:53 pm
Duey Because right now I don't have the means too. I am still not sure which sharpener to get or use. I now understand the difference.
tselliott
Last Name: Elliott
* REQUIRED* Type and Year of Model Ts owned: 1923 Mercury speedster replica, 1923 speedster
Re: Drilling steel?
Post by tselliott » Sun Dec 20, 2020 12:32 am
Cobalt for sure. They may be from China but they are the best drill bits I have ever used. I’m talking about Harbor Freight 115 piece set. I paid $100 and that is cheap for cobalt I’m sure. I got rid of every drill bit I owned after buying these. They work great.
Duey_C
First Name: Duane
Last Name: Cooley
Re: Drilling steel?
Post by Duey_C » Sun Dec 20, 2020 12:58 am
Nice thought about Cobalt bits. :)
I get ya Doc. I play the part of my father in law. He'd say Duey, I'm gonna ask you a question. OK. Tough questions always.
At home I use the bench grinder, at work I used the belt sander with a used belt.
You can do it. We all can if we look and you ain't no knucklehead. :)
Stepping up on my soapbox (OR...Upon this rock, I will build my church. I think of Roy, behind this gruff man was a little rock on the shelf that said that much :lol: ), the best tool for the shop, no matter how big or small, is a working bench grinder with one stone and a wire wheel. :)
Stumbling/tripping off that soapbox, still sounding a condescending jerk. Not meant, my friend. We're all in this together.
ivaldes1
First Name: Ignacio
Last Name: Valdes
Re: Drilling steel?
Post by ivaldes1 » Sun Dec 20, 2020 3:16 pm
No worries Duey! This is a watershed moment when I stop being a drilling child and become a drilling man! Oh say can you see by the dawns early light!...
