Frame Anomaly
richc
First Name: Rich
Last Name: Chillingworth
* REQUIRED* Type and Year of Model Ts owned: 1924 C-Cab TT
Frame Anomaly
Post by richc » Wed Feb 27, 2019 11:41 am
I found spool pieces inserted inside the frame rails on both sides of one frame while looking over some T frames I have. They’re at the rear portion of the frame. Instead of the three rivets being used for the corner bracket, one rivet was left out and this tubular support was in its place. There is a corresponding hole on the bottom rail in line with this unexpected piece. The frame is a 1920–1922 vintage (with holes for both early and later running board brackets). I’m curious if this was original to the frame or whether a previous owner added the spool pieces. Has anyone seen this amongst their frames? Thanks for looking.
Rich C.
Ruxstel24
Last Name: Hanlon
Re: Frame Anomaly
Post by Ruxstel24 » Wed Feb 27, 2019 12:23 pm
I wonder if it's for a trailer hitch mount... :?:
Mark Nunn
Last Name: Nunn
Re: Frame Anomaly
Post by Mark Nunn » Wed Feb 27, 2019 1:34 pm
It may have been added to allow bolting through the frame. Someone may have converted it to hold an add-on pickup bed. My '26 was converted to pickup use early in its life. There is still an angle on the frame to hold a bed extension.
Re: Frame Anomaly
Post by Wayne Sheldon » Wed Feb 27, 2019 3:39 pm
Almost definitely bolted through. For what, could be any of many different things. I have seen similar boltings on speedsters due to suspension modifications. It could also be a pickup box (like Mark N said), or a trailer hitch (as Dave H said), hay wagon rails, fire truck tanks, power pulleys, or any of a bunch of other things.
One must wonder what tales that frame could tell?
John Warren
Last Name: Warren
Re: Frame Anomaly
Post by John Warren » Thu Feb 28, 2019 10:13 pm
Could even be a rear bumper mount?
