[image][/image]
JB Weld or Bondo
Bob in Texas
Topic author - Posts: 46
- First Name: Bobby
- Last Name: Wright
- * REQUIRED* Type and Year of Model Ts owned: 1915 Runabout Fire Chief’s car,1924 Simms TT Fire Truck, 1927 Howe TT Fire Truck
JB Weld or Bondo
JB Weld or Bondo?
(Test post)
[image][/image]
[image][/image]
Bob on Upper Texas Gulf Coast.
"I was too young to know better.
Now I am too old to care."
bobt
- Last Name: Thompson
Re: JB Weld or Bondo
WOW! Some of the paint is still there. Amazing!!!
Adam
- First Name: Adam
- Last Name: Doleshal
That’s nothing special... The left front fender on the T I drive year-round looks worse than that!
Mark Nunn
- Last Name: Nunn
Neither. That should buff right out!
- First Name: Henry
- Last Name: Lee
Ultra Light Weight for Racing! NASCAR approved!
I’ve seen T bones over the years and and I can tell you that one has been out in the back fourty acres for lots of years! T’s left in the open don’t last long in the elements. Just the bones.
Billy Vrana
- First Name: Billy
- Last Name: Vrana
- * REQUIRED* Type and Year of Model Ts owned: '25 homemade pickup, Fond Du Lac conversion tractor
Tires and tubes are doing fine but the air is showing through
StevenS
- First Name: Steven
- Last Name: Sebaugh
- * REQUIRED* Type and Year of Model Ts owned: 1924 Touring, 1924 TT Truck
Really the fender is all there, it's just been "clear coated" The coverage is just thicker in some places.
1924 Model T Touring
1924 Model TT Truck
1928 Graham-Paige model 619
1930 Model A Phaeton
1924 Model TT Truck
RustyFords
- First Name: Don
- Last Name: Allen
The front spring and axle might be usable.
varmint
- First Name: Vernon
- Last Name: Worley
Neither. I use the rusted panel as a template and cut a new piece out of sheet stainless steel, welding .030 stainless flux weld wire to the treated skeleton.
Vern
Vern
Vern (Vieux Carre)
BobShirleyAtlantaTx
- First Name: Bob
- Last Name: Shirley
Please post a picture— pictures of your Fire truck.
Tonight we're settin' the woods on fire!Billy Vrana wrote: ↑Thu Dec 17, 2020 8:49 amTires and tubes are doing fine but the air is showing through
Often it is difficult to see through a project. No problem here.
Bob in Texas
- First Name: Bobby
- Last Name: Wright
By request, my Fire Truck. 1924 Simms on TT Chassis.
[image][/image]
[image][/image]
otrcman
- First Name: Dick
- Last Name: Fischer
Our much-admired artist in residence has commented on the beauty that can be seen in patina and rust. This fender has more patina and rust than metal. I bet Rich E. has the picture saved in his "Pictures to Paint" file already.
Bend a piece of corrugated roofing and bolt in place but be sure to use rusty square nuts.
- Last Name: Patrick
I know this thread is meant as a lighthearted joke, as if the fender is beyond repair and I apologize in advance, for deviating from the fun, but on a serious note, it is not beyond repair. Neither JB Weld nor Bondo epoxy putty alone will work, but a fiberglass repair kit with woven fiberglass cloth and resin would be the way to go to lay down a foundation, using the original fender parts with which to build upon in order to strengthen and form until the fender is strong and ready to shape it into its’ final form. Once you have the foundation, you can shape with a flexible body working rasp, a sanding disc and palm sander and finish it off with Bondo Epoxy putty. Normally, I would remove the rust, but, I believe in his case, removing the rust would totally dissolve the fender, so before beginning the work, I would totally coat both sides of the fender with “Ospho” to neutralize the rust, turning it into a hard black inert substance that will no longer continue to rust and deteriorate. Okay. I’m done. Back to the fun. Jim Patrick
1923orange
- First Name: Thomas
- Last Name: Black
- * REQUIRED* Type and Year of Model Ts owned: 1923 touring
Jim good idea, id like to see it done on a fender like this. Would it be prone to cracking eventually?
Michael Peternell
- First Name: Michael
- Last Name: Peternell
I'm surprised by the bunch of you! My first thought was "a little surface rust, other wise cherry!"
Fiberglass cloth and epoxy resin makes a very strong repair. After all, there are entire car bodies made of it, so I don’t believe a repair of this kind, if done properly, would crack. Jim Patrick.
