Can anyone help me identify this eingine?
Jonah D'Avella
Topic author - Posts: 700
- First Name: Jonah
- Last Name: D'Avella
I have an early engine that does not have mounts for either a starter or a generator. Its number is 116844 but I cant find a date to go along with it. Does anyone know of a way i can find the date? I have been searching through the Ford Model T Encyclopedia with no luck.
- Last Name: Hjortnaes
Re: Can anyone help me identify this eingine?
Do you have a Langs catalog? They have it listed.
ThreePedalTapDancer
- First Name: Ed
- Last Name: Martin
May 1912 or so
Jonah D'Avella
- First Name: Jonah
No, I dont.
Go to Home Page, left top header of this page, open Research in the header there, then Click on Encyclopedia, when that opens, Click on "Go to Old Version". Then scroll all the way down and you will find hot link to "Serial Numbers"Jonah D'Avella wrote: ↑Thu Dec 17, 2020 1:01 pmI have been searching through the Ford Model T Encyclopedia with no luck.
Neat that you have an early T engine.
Join the Model T Ford Club International. The back of the membership card has this handy dandy reference!
- Last Name: Hatch
If it is a”real” 12 block look just above the engine number boss and you may find the date there. Dan
Jonah D'Avella
- First Name: Jonah
Beside it it says 3 25 16 i think
- Last Name: Juhl
Are you sure of the numbers? Can you try to include photos of the serial number and the casting date?
Derek Kiefer
- First Name: Derek
- Last Name: Kiefer
- * REQUIRED* Type and Year of Model Ts owned: 1925 Touring, 1926 Gow Job
- Board Member Since: 2011
You're missing one digit on your serial number. March 1916 is should put it in the 1.1 million range.
Adam
- First Name: Adam
- Last Name: Doleshal
The biggest difference you will notice between a ‘12 block and a ‘16 block is about $2,800.00. They both run the same!
