Are you thinking about LED lights for your Model T?
Bill Robinson
First Name: Bill
Last Name: Robinson
* REQUIRED* Type and Year of Model Ts owned: '21 Depot Hack, '25 Touring Car, '26 Roadster Pickup, '27 Tudor, & another '27 Tudor
Post by Bill Robinson » Thu Dec 24, 2020 8:43 pm
I just posted this video on YouTube about a "before & after" installation of LED's on my '27 Tudor.
Before installation, I focused and aimed the incandescent bulbs according to the Model T Ford manual. After installation of the LED's the only adjustment was aiming each of the lights to the outside slightly so that the edges of the road are lit. I will say that this video does not do justice to the actual lighting of the LED's- lighting is greater than the camera shows.
https://youtu.be/cRh0C0u-gzY
Angmar
Last Name: Bailey
Re: Are you thinking about LED lights for your Model T?
Post by Angmar » Thu Dec 24, 2020 9:16 pm
Great comparison video. I have a mag only car that I diverted the headlamp/running circuit and ran 12 v neg ground to. I installed 12 v LED bulbs front and rear and wow what a difference. Thanks for posting.
Still crankin old iron
Tim Rogers
Last Name: Rogers
Post by Tim Rogers » Thu Dec 24, 2020 9:24 pm
No, my original incandescent setup works great...
Moxie26
Last Name: Jablonski
Post by Moxie26 » Thu Dec 24, 2020 10:30 pm
Bill : I am aware of two types of LED headlight bulbs available to fit Model T negative ground systems. Which ever one is used, I found a video with installation info for a Model A Ford that will help with Model T Ford installation and focus adjustments.
https://www.youtube.com/watch?v=5nXfpvrlQW4.
I left comments below this video..... rain / wind in my area of New Jersey keeping car in garage, but focusing methods are very helpful no matter what LED headlight bulb you may choose. my decision
Moxie26
Post by Moxie26 » Fri Dec 25, 2020 9:27 pm
Bill: Looking at www.ledlights.com will see replacement led bulbs for the negative ground tail and stop light bulbs.... plus offerings for negative ground headlight bulbs.
Moxie26
Post by Moxie26 » Fri Dec 25, 2020 9:31 pm
Mistake ******
www.ledlight.com .
rnwilliams
First Name: Ricky
Last Name: Williams
* REQUIRED* Type and Year of Model Ts owned: 11 Torpedo, 12 Com. Rdstr, 12 Delivery, 2-12 Tou, 15 Tou, 21 Cpe, 25 Cpe 25 TT, 26 TT, 27TT, 26 PU, 26 Tou, 2-26 4dr, 26 Del, 27 4dr
Post by rnwilliams » Sat Dec 26, 2020 1:38 pm
Good job Bill. I have the same light bulbs in my 1927 fordor. They make a huge difference.
Richard Williams, Humboldt, TN
President, Tennessee T's inc.
Last Name: Wrenn
Post by TWrenn » Sat Dec 26, 2020 1:45 pm
Nope. Now that I put an alternator on the Fordor, the lights stay nice and bright, and the ammeter is a fuzz above "0" when they
are on. So why go to all the bother? For what, maybe one or two short runs at dusk or barely dark. Naahhhh.
Jem
First Name: Jem
Last Name: Bowkett
* REQUIRED* Type and Year of Model Ts owned: 1909 Touring #9267
Post by Jem » Sat Dec 26, 2020 5:14 pm
What's an alternator? Next thing I'll be hearing someone talking about replacing the crank handle with an electric motor! Fools! It'll never work.
Pep C Strebeck
First Name: Joseph
Last Name: M
Post by Pep C Strebeck » Sun Dec 27, 2020 11:51 pm
Would it be possible for you to list a bulb number and/or the source which you acquired them from?
Bill Robinson
First Name: Bill
Last Name: Robinson
Post by Bill Robinson » Mon Dec 28, 2020 9:04 am
I understand that there is a shortage of these bulbs presently. Mine were purchased from http://www.snjparts.com/ the first week of December and I got the last 4 they had in stock at that time. Maybe all of the vendors have gotten new shipments. Please notice that these are negative ground.
R.V.Anderson
First Name: R.V.
Last Name: Anderson
* REQUIRED* Type and Year of Model Ts owned: 1914, 1920, 1923, 1923
Post by R.V.Anderson » Mon Dec 28, 2020 12:00 pm
Nah. I use Light Emitting Acetylene, not Light Emitting Diodes. :D
