23 Roadster/newer tranny
tommyleea
First Name: Tommy
Last Name: Russell
Post by tommyleea » Fri Jan 08, 2021 9:47 pm
So, I believe my 23 has been upgraded with a newer tranny. It has the large brake drum, and the hogshead has the screw in mag post. However, it still has the small pedals. Looking at the hogshead, it appears that the mag post area has been welded. Would it have been common to replace the boss of the mag plug, or is the welded boss just the way the were? Thanks..Tommy
Re: 23 Roadster/newer tranny
Post by DanTreace » Sat Jan 09, 2021 10:21 am
Tommy
Appears someone 'modified' that 26-27 hogshead, changed the pedals to earlier, and then ground off the 'lugs' on the top of the hogshead that would allow the 26-27 to mount to the rear of a 26-27 block. Did this to keep the look of a pre-26 hogshead.
Adam
First Name: Adam
Last Name: Doleshal
Post by Adam » Sat Jan 09, 2021 10:43 am
You have to run a ‘26/‘27 hogshead with a wide brake drum because the pedal shafts have different spacing. You can, however, use earlier pedals in the ‘26-‘27 hogshead. There may be some customization involved with the floorboards, or bending the pedals, but it depends on what combination you are trying to obtain.
tommyleea
First Name: Tommy
Last Name: Russell
Post by tommyleea » Sat Jan 09, 2021 11:08 am
Thanks Adam..First, thanks for rotating my picture. That makes sense to me now. I was reading about the differences and the "ears", on the 26/27, which I wasn't sure what they were talking about, now I know. I do have the wide band and the small pedals, so all your info lines up with what I have. Thanks again. Tommy
Chris Instness
First Name: Christopher
Last Name: Instness
Post by Chris Instness » Sat Jan 09, 2021 11:34 am
With the wide drum transmission you probably also have a 4 dip pan. Since the ears on the hogs head are not being used it is probably a good idea to check for pan support brackets on the bottom side of the pan in the corners. Many Ts have run without them, but without the support from the hogshead ears they are a good investment to keep your pan straight.
tommyleea
First Name: Tommy
Last Name: Russell
Post by tommyleea » Sat Jan 09, 2021 11:55 am
I do have the 4 dip pan. I don't think I have any support brackets. Are they visible from the outside?
Post by RajoRacer » Sat Jan 09, 2021 12:49 pm
Yes, they are bolted onto the bottom front corners of the crankcase - one on each side held on by 4 of the block to c.c. bolts.
Chris Instness
Last Name: Instness
Post by Chris Instness » Sat Jan 09, 2021 1:55 pm
Original pan support brackets are pretty easy to come by but you can also buy them new.
https://www.modeltford.com/item/3118-19.aspx
tommyleea
First Name: Tommy
Last Name: Russell
Post by tommyleea » Sat Jan 09, 2021 11:06 pm
OK Thanks
I will get them for installation. Thanks
