Frontenac OHV Cover Attachment
Howard Tomlinson
First Name: Howard
Last Name: Tomlinson
Post by Howard Tomlinson » Sat Jan 16, 2021 4:20 pm
Hello,
I am working on a Frontenac OHV unit. The head didn't come with the valve cover, so I bought one of the reproductions. I am trying to figure out how the bolt to hold the cover down works. It looks like the cover boss lines up the central head bolt. If you all could provide some examples of how you have configured the actual bolt connection, I would appreciate it.[/url]
Thanks,
Howard
Re: Frontenac OHV Cover Attachment
Post by TRDxB2 » Sat Jan 16, 2021 4:52 pm
pics agree with your assumption
Post by Jerry VanOoteghem » Sat Jan 16, 2021 5:04 pm
I believe it uses a special head bolt, with a stud coming out of the top of it that goes through the rocker cover.
walber
First Name: Walt
Last Name: Berdan
Post by walber » Sat Jan 16, 2021 5:11 pm
Yes, special bolt. If you prefer studs to head bolts then a bit long center stud and a couple to take the stud that holds the cover.
Howard Tomlinson
First Name: Howard
Post by Howard Tomlinson » Sun Jan 17, 2021 2:57 pm
Thanks to all that replied.
I'll work up something based on your comments.
Howard
