1911 Touring side curtains
Tomcarnut
Last Name: Muth
Post by Tomcarnut » Wed Jan 20, 2021 9:46 pm
I am having a new top and side curtains put on my 1911 Ford Touring. It does not have side curtains now but the wife wants them after getting a bit wet and cold on the Hershey hangover tour this past year. As this is not a show car and we plan to tour a lot, authenticity is not an issue. I plan to have the clear vinyl windows made much bigger than original to help seeing out. I am looking for pictures of 09-12 open front door cars with their side curtains on. Any suggestions and or pictures of how the curtains connect to the top in front and windshield would be very helpful. I have seen clips to the windshield but do not know any sources. Most interested in ways to make them keep us dry and maybe a bit warmer in wet and cold weather. Thanks for any help!
Tom
Cincinnati, Ohio
Dgpoff
First Name: Don
Last Name: Poffenroth
* REQUIRED* Type and Year of Model Ts owned: 1911 Touring 55276
Re: 1911 Touring side curtains
Post by Dgpoff » Thu Jan 21, 2021 12:52 am
If you get this figured out, I’d be in for a set!
Keith Townsend in Oregon made a set for his car and documented extensively.
1911 Touring #55276
Colin Mavins
First Name: Colin
Last Name: Mavins
Post by Colin Mavins » Thu Jan 21, 2021 10:33 am
I have the patterns for my 12 touring if you give me your email address I can send them to you , they give you all the measurements you need I have made one side for my car .
Colin Mavins
First Name: Colin
Last Name: Mavins
Post by Colin Mavins » Thu Jan 21, 2021 10:35 am
The windshield clips I got from langs repro
Colin Mavins
First Name: Colin
Last Name: Mavins
Post by Colin Mavins » Thu Jan 21, 2021 10:43 am
Colin Mavins
First Name: Colin
Last Name: Mavins
Post by Colin Mavins » Thu Jan 21, 2021 10:49 am
these are the windshield clips cheers Colin
Colin Mavins
First Name: Colin
Last Name: Mavins
Post by Colin Mavins » Thu Jan 21, 2021 11:02 am
You will have to add material if you don't have front doors Keith will have that info. I made the curtains and then fit them to the car using my cars original attaching points as they were different from the step side body. My plans were drawn from the original curtains by my Father.
I hope this helps Cheers Colin
67pontiac
First Name: William
* REQUIRED* Type and Year of Model Ts owned: 1911 Touring 1913 Roadster 1919 TT 1920 Huckster 1922 Touring 1926 RPU
Board Member Since: 2010
Post by 67pontiac » Thu Jan 21, 2021 11:18 am
I have access to an all original late 1911/early 1912 with all the original murphy fasteners in their original locations. I could probably take detailed pictures with measurements. The car does have the fore-doors installed, but it also has the two-piece fire-wall. The fastener locations should be the same as the open-front cars. For those who remember, this is the car Phil Mino had for many years. Contact me if you're interested. The car is on display in a private museum right now and will remain there for an extended amount of time. Call me at: five-five-nine 967-zero-one-one-two.
Tomcarnut
Last Name: Muth
Post by Tomcarnut » Thu Jan 21, 2021 10:19 pm
Colin and 67 Pontiac,
Thanks so much for the information! Sorry it took a while to get back. Work getting in the way. I will call Langs about the clips as I did not see them on their website earlier today. Any help or additional pictures expecially the connection up around the windshield and top at the front would be helpful for my Amish guy who is going to do the work. He has done another 1911 T Top but not the side curtains. Trying to load pictures of my car too. My father bought it as basket case in the early 1950s and restored with the help of his father. Finished it up in 1955 and took it to Dearborn Michigan for the Old Car Fest and got a Blue ribbon which I still have. It was the first car I ever drove at age 13. It sat for many years other interests took its place. Dad never toured with car only driving it occasionally till it became hard to start due to end play in the crankshaft. He had the engine rebuilt about 15 years ago which was a disaster and it took several years to fix all the things the rebuilder screwed up. By then he was too old to enjoy it. I inherited it when he passed in 2015 and took it on the Ohio Model T Jamboree in 2016 and several others. Love driving it but need put on new top and side curtains along with getting some brake lights and turn signals put on. Colin, I also have 1912 McLaughlin Buick model 35 which is only one in the US. There is another one in a museum not too far from Winnipeg. 67 Pontiac I will try to give you a call in the next few days.
Tom
Bob McDaniel
First Name: Bob
Last Name: McDaniel
Post by Bob McDaniel » Thu Jan 21, 2021 10:33 pm
My 13 has no fasteners on the windshield but one on the firewall on each side and on the top. These are the only pictures I took after I put one side on that was under the rear seat of the car that had been parked since 1928. Someone has put black material in place of the clear on the front side window over the years back when these were in use.
dllr28bl
Last Name: Woolf
* REQUIRED* Type and Year of Model Ts owned: 1913 Touring
Post by dllr28bl » Fri Jan 22, 2021 7:43 am
The windshield clips Colin shows are no longer available from the vendors. I finally found some last year after a fair amount of searching. I was able to get the 8 I needed from the manufacturer, but that was the last of his inventory and he was unsure at that time about making more due to the difficulty of sourcing materials because of Covid.
Dan
First Name: Keith
Last Name: Townsend
Post by KWTownsend » Fri Jan 22, 2021 7:29 pm
Tom-
Are you having you top done locally? I'm delighted with the top that Mike from Classtique made for me.
Give me a call this weekend and we can chat about side curtains.
-Keith
