Could this end up to be a problem ????
JohnnyBuick
First Name: johnny
Last Name: Buick
* REQUIRED* Type and Year of Model Ts owned: 1912-13's
Board Member Since: 2004
Post by JohnnyBuick » Thu Jan 21, 2021 12:02 am
Just got these new metal stem tubes in the mail ...
Like a bad Camel they Went from 2 humps to one hump overnite..
Will these conform to the tire evenly once fitted ?
Universal seem to say they will.. your thoughts ??
...An idle mind is the Devils workshop :twisted:
Re: this end up to be a problem ????
Post by Steve Jelf » Thu Jan 21, 2021 12:10 am
Looks like a snake that swallowed a big egg. :)
Do they have a brand name? If they're not Custom Classic I would try them. If they are, I would return them.
JohnnyBuick
First Name: johnny
Last Name: Buick
Post by JohnnyBuick » Thu Jan 21, 2021 12:12 am
EEC type from Universals....
Post by Allan » Thu Jan 21, 2021 8:05 am
The bulge indicates thin spots in the tubes. All tubes will do the same. The real concern to my eyes is these tubes are doing so at minimal pressure. They are still very skinny for the most. The older butyl tubes with which I am familiar will expand to be larger than the tyres will ever allow before there is any swelling at any one point. Is this another indication of inferior rubber supplied by the usual suspect suppliers?
Last Name: Humble
Board Member Since: 2006
Post by Humblej » Thu Jan 21, 2021 9:03 am
I would expect that to happen after the rest of the tube has expanded beyond the tire size, not before, but of course once in a tire it is constrained. I would try it and see what happens.
Post by DanTreace » Thu Jan 21, 2021 9:23 am
Jeff is correct. An inter tube, esp. small bicycle tubes size , with thin wall the T uses, can’t take any pressure outside the tire casing. Result is the tube will expand like that several times it’s diameter.
Adam
First Name: Adam
Last Name: Doleshal
Post by Adam » Thu Jan 21, 2021 9:29 am
If you go looking for problems, you are very likely to find something you don’t like. Even though the pressure is very low to almost non-existent, what you have there are tubes that have been expanded far beyond the size they would ever be inside a tire. Does that fatigue the rubber or make it porous? Maybe, maybe not...
Did the tubes come in boxes with the “Hartford” brand on them? I’ve installed at least 40 Hartford Tubes with absolutely zero issues. All those tires had flaps and I don’t add anything besides the tube, tire, and flap (no lubricant, talc, starch, soap, powder, plastic bags, or any other crutch). The new flaps come from the manufacturer with a small amount of lubricant already on them and it is exactly the right amount exactly where it is needed.
JohnnyBuick
First Name: johnny
Last Name: Buick
Post by JohnnyBuick » Thu Jan 21, 2021 9:53 am
The metal stem tubes u see here came in opaque cellophane type bag and are the EEC brand..
The Hartford ones come only as rubber stem not metal stem that i know of
Post by Steve Jelf » Thu Jan 21, 2021 10:50 am
Some people assume that all products from China are trash, but my experience has been the same as Adam's — no problems with Hartford. I cut off the rubber stems and install metal. I have one EEC tube, but haven't used it yet.
Post by Norman Kling » Thu Jan 21, 2021 11:09 am
It looks like an annurism. :lol: Only way to tell would be to use inside the tire. I don't think it will expand that far when inside. I would install them and let all the air out, then pump up again to correct pressure and do not use them on the road for a few weeks. Then take the car out and slowly drive around. Even take them on a gravel road (if such a thing is clear of ice or snow) and drive around for a while. Once you are satisfied they will hold up, then drive as you usually do. But that's only my opinion, since I have not had any tubes like that.
halftracknut
First Name: randy
Last Name: lee
* REQUIRED* Type and Year of Model Ts owned: 1926 pickup
Post by halftracknut » Thu Jan 21, 2021 11:24 am
question is, has anyone else had this problem...me for one no....I get my long stem rubber tubes from langs and have never had any problems....some other suppliers the rubber stem is too short that makes it hard to air up...my 2 cents ...
Post by Steve Jelf » Thu Jan 21, 2021 11:27 am
...I get my long stem rubber tubes from langs...
What brand?
Last Name: Patrick
Post by jiminbartow » Thu Jan 21, 2021 12:04 pm
As Jeff said, once the tire is mounted and constrainned within the confines of the tire and inflated to the correct pressure it will be fine. I would not worry. Jim Patrick
halftracknut
First Name: randy
Last Name: lee
Post by halftracknut » Thu Jan 21, 2021 3:12 pm
Steve, i am not sure of the brand sorry...but they seem to be made of a good heavy type of material...
Chris Haynes
First Name: Chris
Last Name: Haynes
* REQUIRED* Type and Year of Model Ts owned: 1921 Runabout
Post by Chris Haynes » Thu Jan 21, 2021 3:19 pm
The new tubes from Blockley are absolutely the best you can get. Extreme thick wall. https://www.blockleytyre.com/product/30x3-5-inner-tube
Post by Allan » Thu Jan 21, 2021 10:10 pm
Sounds like the Blockley tubes are made to better standards of quality. Good on them! Finally we have a quality product available in their tyres and tubes.
JohnnyBuick
First Name: johnny
Last Name: Buick
Post by JohnnyBuick » Fri Jan 22, 2021 1:00 am
Thankyou to everyone ..i will fit & try them in near future & list the result...
I saw the Blockley type tube..its a shame they dont make the 30x3 size..
dmdeaton
First Name: Danny
Last Name: Deaton
Post by dmdeaton » Fri Jan 22, 2021 11:29 am
Where are these made?
dmdeaton
First Name: Danny
Last Name: Deaton
Post by dmdeaton » Fri Jan 22, 2021 11:35 am
The valve stems seem to be a little large in diameter around the base of the stem. Will not seat all the way in a 21 inch wire rim. Then its a bear to try and get it back out.
Post by Steve Jelf » Fri Jan 22, 2021 11:59 am
Have you inspected them closely all over? Hartford (China) and Custom Classic (India) are marked with the country of origin. EEC tubes (Europe) don't specify which country. EEC is all they have on them.
dmdeaton
First Name: Danny
Last Name: Deaton
Post by dmdeaton » Fri Jan 22, 2021 12:04 pm
I cannot find any country markings on them
Came from Snyder’s
Post by Original Smith » Fri Jan 22, 2021 2:17 pm
It already is a problem!
JohnnyBuick
First Name: johnny
Last Name: Buick
Re: Could this end up to be a problem ????
Post by JohnnyBuick » Fri Jan 22, 2021 10:19 pm
I recall the 30x3.5 metal stem EEC brand tubes when i first purchsed them in 2009 along with my white tires from Wallace Wade in TX, were made in Vietnam & the 30x3 Universal brand metal stem tubes back then were made in Mexico..
I dont recall EEC making these tubes in the 30x3 size
